A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
screen flickering and turns black at high temperature
Hello as my title states my lg g3 is broken. When i start using my phone for about a minute and the screen starts flickering and then goes black screen. Its weird because my phone keeps running until i turn it off. What could it be hardware or firmware or screen>
Hi,
When the screen blacks out try shining a torch at an angle close to the screen to see if there is still a display there. You may have to look very closely to see it.
If you can see the display then there is a problem with the backlighting which may mean that there is either a loose cable connection from the systemboard to the LCD screen or a faulty LCD screen.
If there is no display at all then there is either a loose cable connection from the systemboard to the LCD screen or a faulty LCD screen.
If you turn on the phone and suspend the display timeout feature and then just leave it there without touching it, does the display still disappear?
If not then holding the phone or movement is causing the problem, again pointing to a loose connection.
If it still disappears then again it can either be a loose connection or a faulty screen.
Here is a link to the Ifixit guide on how to replace the screen in your phone.
LG G3 Screen Assembly Replacement
You just saved me buying a new phone. For anyone reading this who can benefit from my experience; phone was damaged and appeared to have black screen. Shone a light at an angle and the screen was very faintly visible. I turned the brightness up fully and the phone is working. Anything less than full brightness and the screen appears black and unuseable.
Perhaps not only at high temperature, right?
I think this is the "screen flicker fades darkness" problem described for example here: https://www.youtube.com/watch?v=7j88SysX... and here http://forums.androidcentral.com/lg-g3/5... and here https://www.youtube.com/watch?v=gAUkXLR7... , https://www.youtube.com/watch?v=qdg6t_I0...
I tried some of the workarounds and worked fine for some days. I haven't tried the 'bake the motherboard' option, because I don't have any way to verify the oven's temperature is in the proper range
DONT bake your motherboard!
i posted some important infos for y below
https://forum.xda-developers.com/lg-g3/g...
valazquezm12 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,109
