The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Intermittent Screen and Backlight Issue
Hi. I have a 13” macbook pro retina display (Early 2015 model) and I accidentally dropped it from my sofa onto the ground (about 1 feet). There is no crack or lines on the screen. But the screen and backlight will intermittently black (stay off). I connect my macbook pro to external display and it works fine. It seems like there is an issue with my lcd screen. Could you please advise whether this could be lcd connector problem or I have to change the entire lcd screen set to fix the issue?
Appreciate your advise on this.
Regards,
Rizal
Either way you have to replace the whole assembly unless you are up to separating the screen layers apart.
In my opinion, your screen is bad. Usually a bad drop will cause that.
However, you can open the back of your laptop, DISCONNECT THE BATTERY, then examine your LCD connector. Look for physical damage, or see if it is loose by any chance, or try to reseat it.
Use this guide, up till STEP 6 then jump to STEP 11 since at this point you're not trying to remove the screen assembly, just examining, and/or disconnecting and reconnecting it.
The pins on the connecter cable are fragile. Be very gentle, pull cable back not up; make sure it is properly aligned horizontally and vertically before inserting back. Otherwise the pins of the cable can get caught on the edges of the connector and you will have a damaged cable.
Alternatively, if you laptop doesn't look dropped and it is still under warranty, you can take it to an Apple Store or an Apple Certified Service Provider.
rizaru crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,832
