About Memory slots on Mac mini
What happen if the memory removed many time from memory slots many times may happen erosion in the lips that found in the middle of slot "and i mean erosion , the picture clear my mean" and the first remove to the memory i found a simple erosion as the picture clear and i remove the memory in the correct way so it an normal or not
Most of your internal connectors are not designed to withstand constant disconnect/reconnections, that includes the RAM slots.
I would say more than 8 times is about the breakpoint. Why are you swapping in and out the RAM so many times?
Update (09/22/2016)
The image looks just fine! The slot pin is not designed to be bottomed out with the module if that was your concern. Here's an image from the IFIXIT teardown: Memory modules seated correctly in the slot so you can see its the same.
Lets backup here ...
Forget about the RAM for now. What is happening with your system is it working or not? If not explain what you are seeing as best as you can. Did you replace something? Did you smell, hear or see something?
Everything is good i just asking about this point and i didn't smell anything and i didn't hearing anything and i had made Apple Hardware test and the result was " no trouble found "
Thats great! You had me worried ;-}
mohamedhaitham36 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 425
