Shutting down when plugged in.
When I plugged in to the outlet, the screen says ,"All functions will be disabled" then it says" Stand by on/off resume". Then it shuts down.
Had exactly this problem on a 3 year old MFC-J6920DW today - found a solution elsewhere on the net:
Remove power cord and wait 30 seconds. Then remove paper trays. Reconnect power cord and switch on at the wall. Wait for printer to boot (and complain about lack of trays). Reinstall paper trays.
All up and working now!
Fixed problem immediately. (problem started with an inadvertent unplugging of the machine)Did not have to hold power button after plugging back in with trays removed, but some had suggested that. If this hadn't worked, i would have tried removing trays and holding the power button till the music stopped.
Fixed the problem right away! Thank you so much! Gary
Followed instructions about moving paper tray and everything now works. Thanks so much. Janine
03/05/2017: Followed instructions about removing paper trays; plugged in; printer rebooted automatically, then requested insertion of paper trays. All is great now. THANKS!!
I had this issue too and tried several "fixes" without success. I was afraid my printer was hopelessly dead. And, frankly, I had little faith in this suggestion - but it worked!!! I'm back in business and very grateful that someone presented this solution.
Theses methods are only workarounds. Real source of problem is that the supercapacitor (GC.5.5V0.22F) on the motherboard is out of order.
Change it and the printer will work as before.
Thanks to My Brother Printer EMFC-J4510DW won't turn on for the solution !
ok mais comment faire pour changer ce super condensateur de la carte mere (demontage) ??
hello, see here to replace supercapacitor
https://es.ifixit.com/Gu%C3%ADa/Brother+...
or writte in google: brother problema supercapacitor
Yay! Trying to figure it out most of the night thinking my 10yr old printer was gone.
Googled in the & found this tip & bam 5 seconds fixed.
Thanks heaps.
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 138
crwdns2936753:030crwdne2936753:0 647
crwdns2942667:0crwdne2942667:0 88,140
crwdns2944067:024crwdne2944067:0
Is it plugged into a outlet controlled by a light switch? If so , make sure the switch is on. I have done this.
crwdns2934271:0crwdnd2934271:0 Deleted crwdne2934271:0
I have done this also, but the printer wouldn't come alive at all.
crwdns2934271:0crwdnd2934271:0 Diane MacKay crwdne2934271:0
Thanks a lot. This was the solution. I would have never thought of myself. My printer now seems to work.
crwdns2934271:0crwdnd2934271:0 L Jensen crwdne2934271:0
When I plugged in to the outlet, the screen says ,"All functions will be disabled" then it says" Stand by on/off resume". Then it shuts down.how to solve this problem
crwdns2934271:0crwdnd2934271:0 Mukesh Chodhri crwdne2934271:0
please reply me
crwdns2934275:019crwdne2934275:0
