Upgrade screen to MacBook Pro 2013 Retina screen
Howdy!
I've done a fair bit of research the last few days, as it turns out both the 2012 non-retina and the 2013 Retina MacBook pro seems to share the same 30-pin connector for the display in roughly the same place on the motherboard.
My questions is, if I were to do this would the higher res retina screen work and be able to run in native res?
crwdns2944067:015crwdne2944067:0
@danj - Sorry to Re-open this question, But is it possible to get a 3rd party -display cable that makes it to where you can upgrade the display? (NOT to a retina)
crwdns2934271:0crwdnd2934271:0 Ben Capehart crwdne2934271:0
Wishful thinking!the cable in the unibody systems is the exact same pin outs (LVDS) . The displays connector pinouts (T-CON board) is different! I can’t explain why Apple contracted the display makers to use a differed setup. It’s also at a time point the physical connection was not firm only the signaling going down the cable not which physical wire it travels.
I also posted a deeper dialog on why you can’t use a Retina display on a Unibody or the reverse putting a LVDS display on one that needs a retina class display in Marti Bravo Navarro entry.
There is no room to install a pin converter nor does anyone produce a pin converted LVDS cable
crwdns2934271:0crwdnd2934271:0 DanJ crwdne2934271:0
@danj - I may be trying to make it soon!
Can you post the pinouts on the retina and the unibody connectors?
Also what gauge wire should I use?
@beanman56 - just grab the schematics for the give system. Remember uni to uni is only possible.
The retinas are a bit more complex as the standard was changed between iDP to eDP these are not directly interchangeable.
There really is no benefit as you can get the raw LCD’s still for most systems. But it is not easy to open up a Retina display Vs the older unibody displays.
This is not an upgrade in any case! As the screens resolution doesn’t change.
@danj - Is there any upgrade screen panel that I could wire up?
crwdns2934275:010crwdne2934275:0
