Dispenses less water than used to into drink
Get the amount of expresso when pressing button for largest cup
Problems with our K40 Keurig; 1. Machine was taking an far longer time to heat and dispense a cup 2. The amount dispensed was far less than should have been for which ever sized cup/mug button was pressed. 3. 4. While dispensing the flow of discharged coffee from the "funnel" had been neat single column in appearance, but had changed to a multi column discharge stream from funnel 5. The column also splattered the machine and sides of a very wide and tall 17 oz mug requiring the machine to be wiped down after each brewed cup.
I found the machine's manual on line and under trouble shooting it suggested descaling . I used Vinegar and descaled it after a thorough cleaning. During the cleaning I believe there may have been some coffee grounds in the "needle" that I blew the needle out by strong breath. While descaling I carefully monitored the ounces, via a measuring cup, dispensed each time and obtained the correct ounces each time for each sized cup button pressed (or slightly more).
This morning it brewed my cup in the normal time (unlike before) with the proper ounces for selected mug size and I noted that the stream of coffee emitted from the funnel was again a direct neat single column of coffee. Before descaling I was getting from 3 to 7 ounces instead of the 9.25 ounces when I attempted to brew a full sized mug, it took far longer to brew the cup and just didn't sound normal while the column of coffee dispensed tended to spray out of the funnel splattering the machine and sides of a very large mug.
It appears a through cleaning, carefully following the manual's instructions and descaling (Descaling Light had never come on, so I had not descaled the machine in the 8 months we've had it) the machine has cured/corrected all problems.
DID THE PAPER CLIP AND DID GET A BLOCKAGE OUT. Had it working great but now is once again putting out reduced amount of water. Have to run two cycles to get full cup of coffee using largest button. Also machine is making noise as if pump is struggling to pump water into heating boiler. I think this is just about a dead puppy!
have you run Vinegar and water 50/50 thru the maker yet?
I took the machine a part and cleaned every orifice, Checked the check valve, cleaned all the crevices and still having the same problem. It dispenses random water amount. Yes, it looks like the pump is the issue. It seams to me the pump is programed for the time in which the pump can not supply enough water for given time.
Mine is doing the same thing - Random water amount.
Well put.
But I don’t think it’s the pump - because it’s able to pump large amounts of water...
Wouldn’t the pump simply not work if it was bad?
The length of time programming you suggest makes me think there is some kind of computer logic board or relay that has gone bad....
From what I can tell, our K40 is underfilling the coffee cups because the small air pump is wearing out. The air pump is what moves water from the boiler to the K-cup nozzle. When it starts to wear out you will get a full cup with no K-cup inserted (water only), but only a partial cup when you are trying to make coffee.
The air pump is similar to ones used for fish tank (aquarium) pumps. You can find a number of them available at various prices on Amazon, and used ones on eBay. Note that the aquarium pumps lack the metal mounting flange needed for a Keurig, but you might be able to transfer the mounting flange from the existing one. Easier to buy a new pump which has the flange.
Reviews on Amazon note that some of the aftermarket air pumps are not very durable.
There are instructions on replacing the air pump on a K40 in an article at fixing the k dot com. Do an online search for “Keurig replacing the air pump” and you should find the article.
The hard part is getting the side shell off of the top. The air pump is located at the back of the machine, near the center, so you have to remove the outer shell to get at it. You need to take off the bottom, the shell inside the handle at the top of the machine, maybe the handle, and two screws which hold the top on which are on either side if the moving top center mechanism. Then . . .
There are three tabs, two at the back, and one at the right front, which hold the top to the side shell. The tabs need to be pried apart. A very long small ended flathead screwdriver, or similar tool, inserted after you take off the metal bottom, is needed to release the tabs. (I’ve used a 1/8” metal wire stake with the end sharpened, and the other end bend into an oval to give me a handle.) The tabs are hard to see (you need a small, bright flashlight), and it’s very difficult to tell where to press to release the tabs. Shame on Keurig for making an appliance which is extremely difficult to take apart. The fixing the k site has a link to a video which may help. It’s not about a K40, but a K40 comes apart the same way as in the video. I think there are other take-apart videos available too.
I’ve done it once, a year ago, but tonight could not repeat getting the tabs to release. It’s a huge pain. Guessing this is why there’s no “how to” on iFixit.
Good luck.
you could have a clog in the tip needle where the coffee goes check that first..
try unfolding a paperclip and stick it in to the needle then try it again. you may need to dig a little if there is a lot in there
crwdns2942667:0crwdne2942667:0 1,677
Your question needs work and a better explanation of your issue.
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
