The condenser housing may be cracked, but usually water on the floor means the drain is clogged. Somewhere on the firewall there is a small rubber tube that comes out and doesn't have an end on it. This is the condenser drain. You should be able to push a coat hanger or something up into it and push out the dirt and leaves or whatever is that is blocking it. This should take care of most of your problem. If it doesn't and the housing is broken; at least you didn't have to spend any money trying this first. ;-)
The "housing" is the part of the heater assembly that holds the condenser. It is usually part of the hvac assembly and is not a separate part. You will have to replace the whole hvac casing. I'd try the free fix first.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
