Should I replace Motherboard?
Hi all,
My camera is not charging or responding to anything, either plugged in into a wall charger or laptop ect.
Background:
I believe I damaged the motherboard by charging it with a crap usb charger (output of 5.35V). It smells a bit like burnt electronics and it heats up if I connect it to the power. Even with no battery, the camera does not respond. I have tried other batteries so that is not the issue. I have tried other cables and is not the issue either.
The camera is out or warranty and GoPro support wont even try to look at it :(
The Question:
I believe that the charging circuit/voltage regulator is part of the Motherboard. However, I am afraid that this would not solve my problem (ie. may have damaged other parts of the camera). I am an Electronics Engineer and I am able to replace the board.
Just wondering if someone has done it before or had similar issues??? I do not have a schematic to diagnose the fault so it is a risk if I decide to replace the motherboard and it does not work....
Thanks for taking the time to read this
Cheers
Here's the guide on replacing the logic board: GoPro Hero4 Silver Motherboard Replacement
Here's the part: GoPro Hero4 Silver Motherboard
crwdns2886500:0Replace a corroded, damaged, or malfunctioning main circuit board assembly. This part is compatible with the Silver Edition of the GoPro Hero4.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$54.99
Hi guys,
I have a similar problem. I did purchase a new mobo and followed the replacement guide to no avail. My Silver still won't turn on.
Do you guys have any idea what else could be the problem?
Novice RC crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 647
