Replace HDD with SSD?
Hi,
I want to replace my primary HDD with an SSD. So I don't want to replace my optical drive and I don't want to add the SSD as a secondary drive.
I am searching for the best option with a hardware thermal sensor adaptor/cable or a similar preferred and established solution for the iMac Intel 21.5" EMC 2389 mid 2010.
So which parts (thermal sensor adaptor + 3.5 case for the 2.5 SSD) should I buy and where can I buy them? And is there a SSD to prefer?
Thank you very much in advance for your answer.
Unfortunately SSD's don't really come with thermal sensors so when you install it the fans inside the Mac will run at max settings, it can get pretty loud. A good workaround is the use HDDFanControl. This will allow you to control the fan speed.
Now for the SSD that I would suggest it has to be the Samsung Evo 850 Pro but if you're looking for a cheaper option you could go for the Samsung Evo 850 (non Pro) still has incredible read/write speeds. For mounting you can use this converter bracket.
The better solution here is to use this: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade I strongly recommend going with the hardware direction over the software approach. Time has shown us the software direction is not as good. Systems tend to overheat and fail prematurely using it.
You'll also need an adapter frame as the SSD is a 2.5" drive Vs the current HH with is 3.5" Here is what I recommend: OWC 2.5" to 3.5" Drive Adapter Bracket. Since you'll need to order the sensor you might as well get the frame too.
Thank you very much for your answers. I will try the OWC In-Line Sensor in combination with the Samsung Evo 850 500GB.
@danj : Is the adapter frame you've posted compatible with an iMac mid 2010? I'm a bit confused because in the reviews in your link, the users write that it does not really fit into an iMac and that they should have gone with the Newertech AdaptaDrive.
On the other hand I find the Newertech AdaptaDrive somehow strange because of the extra SATA port between the drive and cables. It seems like an unnecessary and potential source of error.
What's your opinion on that?
If you look at the image you'll see the adapter is not symmetrical. So it you put it in the wrong way the SATA cable can be a bit short. I suspect they put it in backwards and yes the added interface adds an error point in the Newertech unit.
I received all parts mentioned above and installed them. While installing I removed the extra SATA port on the Newertech AdaptaDrive since I think it is useless for my purpose and so I connected the iMac SATA ports directly with the OWC Thermal Sensor to the SSD's SATA ports.
The iMac is working and I installed 'OS X El Capitan'. Sadly it seems that the 'OWC Thermal Sensor' is not doing its job correctly. At a room temperature of 25°C and 15 minutes after starting the computer, it is showing 32°C for the Hard Disk respectively the SSD temperature and so the fan is turning at about 4340 rpm. Both, the showed SSD temperature and the fan speed, are constantly rising and the fan noise is getting louder and louder.
Now about 30 minutes after I turned on the computer the SSD temperature is showing 35°C and the fan is turning like mad at 6030 rpm.
The CPU is at 40°C and the CPU Fan is turning at 1198 rpm.
The optical drive fan is turning at about 1000 rpm.
I opened the iMac again to check the sensor cables but everything is connected correctly. I already done a SMC/NVRAM/PRAM reset.
I thought that the 'OWC Thermal Sensor' will solve the 'fan noise problem after a SSD <-> HDD replacement ' without having to use a special software. But it seems that it only hands the SSD temperature to the OS and then the OS is handling it as a HDD and speeds the fan up as it would for a HDD. Maybe somebody knows more on that but shouldn't the fan turn slower because it's an SSD? What are the normal fan speeds for average temperatures?
Or maybe the sensor is simply faulty.
I did not contact OWC yet but for now I installed the free software 'SSD Fan Control' and I think I'm going to live with this software solution since it's really annoying to take apart the iMac a third or fourth time to get out the sensor and send it back to OWC and then wait for a new one and try it again and so on. Also I'm living in Austria and shipping costs are therefore another reason.
I read that a SSD is not generating that much heat as a HDD and that overheating should not be a common problem with SSDs. Is that true?
I will use the option 'SMART' in 'SSD Fan Control' and there I set the following configuration:
1100 rpm @ 45°C
6300 rpm @ 70°C
So now the software 'SSD Fan Control' is showing me 39°C for the SSD temperature and 1500 rpm fan speed. I barely hear the fan now and it is really great.
Is this a good solution or are there any long-term problems with that?
Sounds like you have a bad one or something got damaged in the process ;-{
bbb crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,187
