Sea water soaked, not turning on.
Sea water soaked, not turning on, what could be possible damages caused inside phone? Where can i fix in Phuket, Thailand?
@nekx the major issue you will run into is corrosion damage. Salt Water will get your components to corrode very severely. The very first thing I would do is to disassemble it by following this guide Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water (that might have helped right after it got submerged in the sale water). Use a soft brush and clean it very, very thoroughly with the sterile water. For a proper cleaning , you must remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. Use this guide for that. It will fail if you do not take care of it now. Keep in mind that water damage is the hardest to troubleshoot and to repair. If it's worth the time and money will depend on you, your skills, and your finances. I'd definitely give it a try. There is always a chance and what a great challenge that will be.
As in where to get it fixed in Thailand, that will be up to you.
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
1 - 2 hours
crwdns2937801:0crwdne2937801:0
15 - 20 minutes
15 - 20 minutes
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 453
hi
the chance of you fixing it is very minimal as sea water is very bad for electrical components
the damaged caused can vary from very easy fix to a completely dead phone
crwdns2934271:0crwdnd2934271:0 Alex Hus crwdne2934271:0
