Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
Slow Bootup And Slow Startup
I have been haveing a problem with my laptop were it takes like about 3 minutes for it turn on and when i sign in it takes another 3 minutes to star all the programs up
I have some programs disabled from starup like for example : skype
I also Have a problem were windows defender wont turn on and an error pops up saying :
C:\Program Files\windows defender\MSASCui.exe Windows cannot find 'C:\Program Files\windows defender\MSASCui.exe'. Make sure you typed the name correctly, and then try again.
And I need help.
Update (12/13/2015)
how do i install defender back ?
Update (08/08/2017)
I dont need help anymore since I found out my self, it takes around 30 seconds in total to boot up
Since im a computer fixer, i found a way to increase the virtual ram memory to 12,000 and increase the intel raphics card vram to 712 in regedit.
Hi,
Here is a link which shows how to "troubleshoot" problems at startup with Win8.1 and Win10 (you didn't specify). Go to advanced options and decide from there. It sounds like there might be a problem with Defender. In the advanced options , there is windows start up options. Disable defender and see if this improves your startup. If so you may have to uninstall / reinstall defender.
http://www.howtogeek.com/107511/how-to-b...
You may also want to run a sfc scan
https://support.microsoft.com/en-us/kb/9...
Hope this helps
You may also want to run a virus malware scan. They often attack windows defender
You can try to optimize your boot from settings too.
Here is good video for win10 https://www.youtube.com/watch?v=YbC7QIia...
And your win defender error occurs because your saved path to program files is wrong. It can occur when file is move to different place or the file structure is change so the program can't read it.
Had same slow boot with Windows 10, fresh install following hard drive replacement. Was taking 1 minute 20 secs to load windows. On a Lenovo z50. Found the Bios time and date was incorrect. Set the time and date correctly and now takes 8 seconds. Vast improvement but no idea why this would cause it though I did notice Windows set its own clock. Must have been of the internet somehow.
how does the comoputer know thats its a right date anyways ?
Angel Galvan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 11,576
