The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Brake Lights stay on
2002 dodge ram 1500 truck light switch is off but brake lights are still on. I have no fuse book to my truck.
Check the pedal switch if it is not properly adjusted the brake light will come on as if the pedal was being depressed. You may also want to check the spring return on the brake pedal if its not tight enough the pedal will sag and the light will come on. Hope this helps
Check it still no help someone please help me
jhudson8265 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,024
