Where can I buy a replacement battery?
I am looking for a replacement battery for my JBL Flip 2 Bluetooth Speaker because it seems like it needs one. The battery drains so fast and it takes way too long for it fully charge it. However I can seem to find one on eBay or Amazon. Any ideas?
crwdns2889612:0crwdne2889612:0 7
Where can I buy input charging pannel of my JBL flip 2 .
is there “How to” Instructions on the removal of outer case or speaker cover of the JBL Voyager Portable Bluetooth Speaker to check the rechargeable Battery
crwdns2933315:09crwdne2933315:0
i have found few things !
http://www.ebay.com/itm/Rechargeable-Pol...
looks kinda sh*t quality...i have no idea there are soooo many to chose from
also i have found this !
link
also this person says that the battery isn't problem in his case....something weird could be going on...
Thanks for your help! As long as it functions better than what I have now, I'm cool with that. I'll post the result of the new battery replacement.
I want jbl flap2 bluetooth speaker battery. Find me the place or if u can send me the battery on my address i will be greatful.
yes but it's not original
i mean in modern bluotooth speaker you have so li-ion or li-po batterys
so just take your off and check the numbers on there (and post foto)
it should say
-type
-number of cells
-capacity
than you can go to ebay and just search for simmilar one or maybe even the same (justr ask here before buying)
or just post here your results and we'll check some on ebay
also don't buy cheapest $@$* you can get hold on
Okay so I was able to remove the battery.
The battery model is AEC653055-2P
Rating 3.7V 2000mAh
Did you replace it? Any recommendation?
I find a replacement battery with connector here
JBL Flip 2 replacement battery
Battery is not charging my speaker
ihave jbl flip 4 speaker battery drains after from were I can the battery to replace from mumbai
i will suggest you buy battery in only winter season because in this season you will find so much low rate. best schools
ihave jbl flip 2 speaker battery drains after from were I can the battery to replace from goa
chaubly crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 15,322
