MOUSE is not working
My mouse suddenly stopped work. The batteries are new but the green light does not turn on and does not work. Is there a way to fix it. I appreciate your assistance. Maria
I had the same issue. I used a Q Tip and some rubbing alcohol and cleaned all four battery contacts with the wet alcohol. Then I used the other end of the Q Tip (the dry end) and dried the terminals completely. I replaced the metal back and turned on the switch and the green light turned on right away. Hope this helps!
This simple solution worked for me, thanks! My v1 Magic Mouse has been working perfectly since I purchased it in 2009. Today it suddenly stopped working. I removed the batteries and examined the terminals. I discovered that the + terminals were cloudy, especially the one on the left. I used a Q Tip and a tiny amount of Deoxit contact cleaner to clean the terminals. Nice and shiny again. Put the batteries back in, turned it on, and all is well. Very glad I can keep using this peripheral.
First try restarting the computer that uses this mouse. If it fails to start working:
un-pair the connection... restart machine again... then repair the mouse with the computer. You should be good to go. If not, then you either need to check to see if you need to do any updates...
Worst case scenario, the hardware in the mouse went bad. In which case you can either do a tear down and attempt repair... or search macsales.com or amazon for a replacement. With Black Friday around the corner deals are all over the place. I believe I saw one as cheap as $30.
I'm not sure that it would pertain to this situation...
If you want to try a SMC reset prior to a teardown or replacement... make sure that you have a backup of your drive and the data on it. Then do a search for " SMC reset" and the model of your Mac computer. Click on the link that leads you to the apple forums. There you will see a full example of how to do a SMC reset.
Sometimes things like SMC resets and even PRAM resets tend to knock out any weird "cobwebs" that tend to bother Macs.
Happy computing and good luck.
crwdns2959996:0crwdne2959996:0 2,198
my magic mouse has stopped working on a mouse pad, but works fine on a table. Weird. No problem with my wife's mouse which is identical. any explanation? for this?
crwdns2957956:0crwdnd2957956:0 Bancroft crwdne2957956:0 crwdns2950251:0crwdne2950251:0
