Bose Soundlink Bluetooth Mobile Speaker II was originally released in September 2012 as an upgrade from the original device. It has an effective range of 30 feet and a battery life of up to 8 hours.
I can not pair my devices
I'm having trouble using the Bluetooth and connecting my two devices.
What operating system are you running and on what machine?
I would like to know if it is possible to run the Bose Soundlink II with a computer on Linux ?
This device is no longer supported by Bose so I cannot update. I cannot therefore connect by Bluetooth from my iPhone XR.
The XR port needs a lightening connector but I am unsure what jack I need at the other end to connect to the Bose Speaker
The most common problem with bluetooth connection is the device and the speaker are not paired correctly. Make sure the device is trying to connect with the speaker and not with any other devices. Also make sure the device isn't trying to connect with multiple devices, as that can prevent connection.
Since I'm located in Lubbock, would you mind sending me some info or a link to TTU-RAUCH-F15S22G4? Thanks! Guns Up! Beat The Horns. Just click on my name to get to my profile.
Kevin Bailey crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 564
