The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
What can I do do fix my chrome book?
I dropped my Chrome Book and now when I turn it on half the screen is white and the other is black. If I bend the screen, a little bit of the home screen will show. It also had colored lines, large black spots, and a white line across the screen. Is there anyway to fix it? My screen lookes like this.
hi my name is allen and i got me a new chrome boo k and i would like to how do you clean it i never have one of these thanks
Hi, I'm sure you've resolved this by now but your LCD is shattered, it will need to be replaced.
Hello!
It sounds like you have broken the LCD screen. This is an easy repair, so don’t sweat!
Feel the top width of the laptop screen, you should feel a slight ridge. This is where the front screen bezel snaps in. Using a guitar pick you can gently pry the bezel off. From there, there are four screws in the four corners of the LCD screen. Unscrew those, gently pull back the screen to rest on the keyboard. You will see a cable ribbon, gently disconnect this from the LCD screen. Order a new screen per your device specs, connect the cable ribbon to the new screen, screw the 4 corner screws back in, snap the bezel on, and you are good to go. There are plenty of detailed guides on iFixit, for a screen replacement it does not need to be an exact match to your model for you to get the gist of it. Good luck!!
yourstrulybree crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 722
