Why is the lid so hard to remove?
After using my Ninja blender, the lid is always stuck. I always have to ask my Dad to remove it. Why is it getting stuck after I make my smoothies?
If you use the dishwasher to wash your blender components, make sure to allow several hours for the all the water to dry, especially for the lid. If there is still excess water between the seal of the lid, it can create a tight suction and make taking off the lid difficult after blending.
still stuck it sucks
Still extremely difficult to remove. I've stopped using the blender because of this. It's a real design flaw.
I have the same problem!
Same here. If it isn't tight enough liquid leaks during the blending, but if it is tight enough for that not to happen it is extraordinarily difficult to remove. I've mostly stopped using, too.
After trying everything to get the cover off, and no I did not wash it in a dishwasher, I used some WD-40, and it came right off. Use a good degreaser to wash the WD off. Blue Dawn dish soap works great.
crwdns2947631:0crwdne2947631:0
I used hot water, no help, tried to pry off, would not budge. I was spraying a squeaky hinge with WD 40 and decided if it would unstick other things, it might unstick the lid, one squirt on all 4 sides, and the lid came right off. Now I know to not store with the lid on.
If you haven’t used it for awhile and it is stuck on, you have to muscle it. A man with big hands ( sorry feminists) and fingers should be able to do it easily. I am a medium build man y with skinny fingers. Undo the latch, place the tips of your fingers under the edge of the lip and pull like crazy. It hurt so bad that I used a dish wash cloth. I put my left arm around the pitcher, gripped it, gritted my teeth, told the lid that it would lose and I pulled it right off. Suggestion: don’ t store with the lid all the way down.
I used Olive Oil around the lid edges. It took many tugs to pull it off as I am not very strong but dont give up. It took me about 5 minutes of tugging for it to finally come out of the blender.
Put lots of rubber on the lid,twist and will open easily.
Mine leaks and so I wanted to replace the seal.
I was unable to find a genuine seal on the Ninja website, so I called them…..
I was informed that you need to buy the whole new blade set as they don’t sell the seals.
I won’t purchase another Ninja for this reason.
don't put lid put in side
I do that still stuck it sucks
The rubber is may be missing or off the lid.
Twice I tiressly struggled to take off the blade lid I realized the clear plastic circle that goes in between the blade lid was off.. I usually take it after using the ninja when cleaning
I just used a table knife to carefully pry it off.
Actually, the big thing that you need to loosen the cup from the blade is a good grip. I finally realized that by putting on simple dishwashing gloves I was able to grip both the base and the cup and give it enough of a pull to where I could separate the two. I find that it only gets stuck if I overfill. Hope this helps!
Super simple fix to remove the lid. Fill pitcher with hot tap water. Let sit for 60 seconds. Then slowly pull off the lid. I’m a petite woman with small hands and I was able to pull off the lid after this quick fix. From now on, don’t store with the lid on.
Boiled hot water, set it in pot for 5-10 seconds, used rubber mit twisted hard still a little tight but did come off!
Problem solved. Most people are not lining up the arrows (small white arrows) on top to each other. There is a small pin that locks the lid tight when properly aligned. When you push down on the release button, and pull up on the handle; it easily releases. I would also leave the lid loose on top when not using it, as other people have suggested.
Put lots of rubber on the lid,twist and it will open easily.
I am lined up but cannot get it to pull off after pressing release button. Could the blade inside be holding lid in place? Never used it yet.
I finally got it pulled off!
I never use a dishwasher b/c my grandma hated them. Something about food traps.
I bought one of those professional Ninja blenders due to my boyfriend needing to be on a liquid diet way longer than expected.
He’s still on liquid diet. And he also hates dishwashers. We wash everything by hand. Super hot water! And air dry.
I did notice that the lid likes to stay on after use!
But I noticed if you lifted the pour cap before you need to lift the top off [and depending on what I blended & how much & what temp you blended that could affect how hard it is to get the top off. Especially if you still already had water & didn’t know in the compartments you can’t see as well as integrity of the seal(s)] ….
I noticed that if I lifted the pour cap first that made taking the top off a lot easier. Even with all the other variables.
Once I realized that, I decided to hone in on the other variables to make it a lot easier each time.
Also, even though I hand-wash that doesn’t mean water never gets into the small compartments like the release button. I try my best to reduce the amount water that gets into there now.
But still some will get in. So after I’m done I always turn it and hit the release button so the excess water just drains into the sink before I let it air dry.
Such a pain!
I hope this helps. 🙂
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 293
crwdns2942667:0crwdne2942667:0 111,849
crwdns2944067:012crwdne2944067:0
Having the same problem… Will never buy another Ninja product… Too frustrating…
crwdns2934271:0crwdnd2934271:0 John Warner crwdne2934271:0
Mmmmmmm...... it is a good product; just don't store with lid on tight...
crwdns2934271:0crwdnd2934271:0 Ed Sanford crwdne2934271:0
Look where the handle attaches to the lid, you will see white latches, one on either side, lift them up with either a small flat head screw driver or, the blade of a pair of tweezers. The lid will come off just like magic.
crwdns2934271:0crwdnd2934271:0 shekinah3361 crwdne2934271:0
I used Pam spray and pried it off with a flat head screwdriver. I won’t store with lid on and lightly spray lid before usage.
crwdns2934271:0crwdnd2934271:0 Laura Miller crwdne2934271:0
Same problem years later - so frustrating. Will never buy another Ninja product.
crwdns2934271:0crwdnd2934271:0 Megan McLean crwdne2934271:0
crwdns2934275:07crwdne2934275:0
