Business desktop computer manufactured by HP in 2007. Green PC certified / Intel Core 2 Duo processor
will it work with an intel slb6b processor?
have 2 gb of ram 159gb hdd wirh a intel dual core 1.80 processor and it hangs or stalls when using propresenter 5
the intel processor is 2.66 ghz / 6m /1333 /05A.core 2 quad core
What are the model specifications on your current processor? You can check the socket of the compare those specs with those Intel® Core™2 Quad Processor Q9400S against what you have as a starting/reference point.
Most likely, but still possibly not. The motherboard may not support the specific processor, but it is worth a try. The socket is the same. But you may need to install a new heatsink for the new CPU. It has a higher Thermal Design Power.
Check this link if you need help installing a CPU:
HP rp5700 Repair Central Processing Unit(CPU) Replacement
The rp5700 only supports CPUs with a 1066 MHz FSB. The Q9400 (SLB6B) has a 1333 MHz FSB. The fastest CPU supported is a Core 2 Duo E7400.
Aeryn TwoFeathers crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 638
