Processor: Intel® Core™ 2 Duo Processor T5750 2.0 GHz
crwdns2934055:0crwdne2934055:0
Why is heating my laptop
how do i resolve problems with heat in my processor
You may want to replace the thermal paste. The fan and heat sink can be removed with this guide.
If your new to thermal paste installation, check out this.
crwdns2886500:0Electronics Skillscrwdne2886500:0
crwdns2930805:0crwdne2930805:0
How to Apply Thermal Paste
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
5 - 20 minutes
crwdns2886500:0Gateway SA1 Cooling Fancrwdne2886500:0
Gateway SA1 Cooling Fan Replacement
crwdns2937799:0crwdne2937799:0
10 - 15 minutes
hi there. with regards to your problem, may i know how old is your notebook? and in what places you're using this? for the first possibility of overheating is DUST on your fan. the longer we use our notebook the more dust it will take inside. and for the place where you are using it...if you use this in a room where dust are everywhere then you need to open your notebook to clean only your fan. then try to boot again.
second possibility is that your fan needs to be change when it rotates very slowly. hope this will help. cheers.
1. Remove dust from heat sink
2. Replace thermal grease between processor and heatsink
3. Use your laptop on a flat surface
i need new batery
crwdns2942667:0crwdne2942667:0 3,396
