crwdns2934055:0crwdne2934055:0
system showing blue screen
my system got windows failure and when iam trying to install it the system shows bluescreen showing telling that your system must be shut down to cause any harm to your computer and asks to try disable newly installed hardware or software then disable shadowing and catching
There are several steps to take
1. Boot into the safe mode and run anti-virus and anti-malware
2. If you have recently installed a program remove it and see if the problems gone
3. If you are using XP or newer operating system use a restore point before the problem started
4. Boot to your Operating System disk and run system repair.
5. If nothing has worked to this point it is now time to format and reinstall your Operating System. You should have received a restore disk with your computer. Install it - boot to your optical drive and follow the instructions--no need to pay someone to do it for you.
If you have questions try back to us and we will try to answer them. Ralph
+ agreed
crwdns2947631:0crwdne2947631:0
crwdns2947633:0crwdne2947633:0
That blue screen is called the blue screen of death, which means you need to bring the computer to a technician and have them format the hard drive and reinstall the operating system, I hope you backed up your files because you will lose them
crwdns2942667:0crwdne2942667:0 1,271
