Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Possible chip damage? Phone reboots every 2-4 minutes.
Hello,
A customer has brought me an iPhone 5C for power issues. Upon opening the iPhone I can see that the screen has been previously replaced. Phone appears to be clear of water damage.
The phone reboots every 2-4 minutes, either plugged in or not plugged into a charger. Replacing the battery makes no difference and restoring the phone through a DFU does not fix the issue.
I have managed to locate some board schematics but have not a clue which area and chips to look at.
Hope you can help.
Thank you kindly.
same problem- you ever find a solution?
Unfortunately not yet. Definitely think this is chip related.
Bad battery or missing filter near battery connector
Thank you for your reply. I have tried a few batteries with the same result.
What am I looking for in terms of these filters?
Board examination is completely new to me.
Thank you!
I have same problem with iPhone 5c. I have three missing components. As in the picture at the top FL11 and the two below it. Jessa can you tell where I can find those replacement components. I have olso iPhone 4 donator board. In iPhone 4 chemantics there are FL11 but it still missing from every iPhone 4. There are many Fl components in iPhone 4. Is that same thing If I replace Fl11 with for example FL23?
The Filter you are looking for is FL11 and is extremely small. I've attached a picture with the filter circled in red.
check for any components knocked off around the battery connector. unplug battery and charging port to inspect. microscope is recommended
Thank you. I will inspect under a microscope. Upon eye's view, the components seem to be okay when compared with another board.
zentech crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 222
