Can replace for mbp retina 15"early 2013
i have a early 2013 mbp retina 15", track pad done work, can i replace it?
I noticed you mentioned the 15" model but tagged the 13 inch. Assuming that you have the 15 inch model, here is the disassembly guide, and you can stop when you get to step 38. Here is the trackpad replacement guide (meant for the 13 inch, but it still applies). You can order the part here. Before you purchase the part, check to make sure the trackpad ZIF cable is properly seated on the logic board and is not loose, since that could also be causing your problem. These cables are sensitive and can become dislodged.
crwdns2886500:0MacBook Pro 15" Retina Display Late 2013 Upper Case Assemblycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
MacBook Pro 15" Retina Display Late 2013 Upper Case Assembly Replacement
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
2 - 4 hours
crwdns2886500:0MacBook Pro 13" Retina Display Late 2013 Trackpadcrwdne2886500:0
MacBook Pro 13" Retina Display Late 2013 Trackpad Replacement
1 - 4 hours
hi Robert, thanks for answering, i got another problem, all the trackpads i find online are for late 2013 and this one is early 2013, i dont have the mac to check im buying it and thats the issue with that mac, he says it just stopped working. it might be what you say. Coming back to my comment, is there a different trackpad for mbp 15"retina early2013 ?
This appears to be the one for that model. When the laptop comes in we can troubleshoot the issue further.
crixelf crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 562
