Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
home button not working after front panel replaced
Okay, two issues really: the home button is not apparently working. and the screen is acting funky. My LCD wouldn't light after replacing a shattered front panel (used the fixit kit and guide) so I removed the new front panel and reseated the connections for the LCD cable and the digitizer cable. LCD still dead so I followed the advice posted elsewhere on this site for a hard reset which worked, but touch panel was acting funky so I did a restore, then a reset (yes it was backed up first). Now, it seems the home button doesn't work, and there may be dead spots on my digitizer since I can only select the lower WiFi network displayed and not the upper, and I can't get it to respond to either button on the warning box that appears lower on the screen. One stupid question before I tear the cover off again: is there a piece of tape over the home button area I didn't remove that would be blocking it? I don't remember one, but I would hate to replace the home button ribbon connector if that could be it (then again, either way I have to pry the front panel off again). And is this clear evidence I've damaged the digitizer cable (I was very careful,even preserved the WiFi antenna)? Also, the digitizer activates the LCD, and sometimes seems to respond as if I had pressed the home button, when I touch the bottom border of the iPad screen (the black area) which it never did before.
crwdns2889612:0crwdne2889612:0 -1
You have posted your iPad to be the 3rd Generation but if you have an iPad with a home button ribbon cable then you have an 4th Gen iPad. If your home button doesn't work, it could be that you have damaged the ribbon cable or the cable is pulled out of the port on logicboard and needs to be pushed back in, or the clicker part of the home button (the part that sites right behind the round plastic home button) is bent out of shape so when you push the button, the back of the plastic part doesn't reach the clicker because it is bent and too far from the button.
If you touch the black area of the digitizer and the LCD screen comes on, it usually means that the home button is not aligned right under the digitizer so when you touch the black part of the digitizer around the home button, the glass pushes on the home button/clicker underneath the glass and activates your iPad and LCD comes on. If this is happening, then you home button still works and you need to disregard what I said on the first paragraph and just align the home button underneath the glass so it is not pushing up against the metal parts/frame around it.
With regards to your screen having ghost clicks, or not responding to touch, you might have purchased a bad quality defective digitizer screen. There are tons of bad quality digitizers in the market that are defective.
Thank you. It is, according to Apple (based on serial number), a 3rd generation iPad. To be honest, I'm pretty sure I didn't damage the home button cable, but I will check it, as it seems I am destined to open this thing again. The case around the home button is undamaged, and the front panel assembly was ostensibly brand new from ifixit.com, and, in any case, is undamaged so far as I can see. I'm not sure how the button could be that misaligned, but I can play with that when it is open as well. I did try adjusting its position a little before adhering the glass, as it wasn't working then either, but I wasn't sure if that could be due to the raised glass panel.
Is there a way to test the home button function without the button/glass panel in place? LCD would have to be in place, I imagine.
I agree with Ron. iPad 3 dos not have a ribbon cable. I it is an iPad 4, you should be able to press the home button without having the digitizer completely in place. If it's an iPad 3 you can us a piece of metal to bridge the gap between the two pins on the charging port. Just make sure that the digitizer, and lcd screens are connected to the logic board. I've run into problems from energizing the iPad without them in place.
Hello everyone,
I am having somewhat the same problem as cstr8. My sister owns an ipad 4 and I recently replaced her digitizer. After completing my repair, everything worked perfectly except the home button. Then, I opened it again, unplugged the home button/charging port flex cable and plugged it back in.
Still didn't work but I realize at this point that when I pressed the unglued digitizer on the two metal pin, it worked just as if I pressed the click button. It's weird to me because the button seems to work (when I press the little piece onto the two metal pin) but it does nothing when it's well pressed and I used the click button.
Thank you for you help, it is very appreciated, have a nice day!
Alex
cstr8 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,683
