On the left side you should see a battery tester depress the tester button and see what the it tell's you.
Did you install OS-X on to the HD? If not you'll need to find a friend who has a Mac to create a bootable drive.
In this case I would get a 32 GB or bigger USB thumb drive (or external HD) and have your friend format and install OS-X on it. As you didn't tell us the exact model you have I can't tell you which OS version you'll need (oldest your system will support). You likely can use the newer versions Mavericks (10.9.x) & Yosemite (10.10.x). Make sure your friend tests it to make sure it boots up his system and then copy over to it the OS installer as you'll need it for your system. Use the drive you setup to see if you can get it to boot up your system.
Does the system have memory modules installed? If the drive was pulled I would expect they pulled the RAM too. If not present you'll need put in at least 2GB.
If you got to this point and the system still isn't running lets try doing a SMC reset. Follow this Apple TN: Intel-based Macs: Resetting the System Management Controller (SMC).
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2944067:04crwdne2944067:0
Please supply us the last four digits of your serial number so we can identify your exact model.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
DC79
Model no A1297
ser no C02DV1YWDC79
crwdns2934271:0crwdnd2934271:0 jaypieces crwdne2934271:0
MacBook Pro 17" 2.53 GHz Core i5 (Mid-2010)
I tried the smc reset and lost the keyboard again
