MacBook Pro screen issue - black goes green (after falling)
Hi guys!
I have this issue on my MBP - after my laptop fell down on the floor the screen changed the color. Now instead of black I see green, some dark colors turn into flickering green. If I move black object around the screen - the green flickering shadow follows the object.
First couple weeks the problem disappeared after a while - just don't disturb it ~10 min and the colors come back to normal condition. Now it doesn't help mostly (but sometimes though colors return). When the color changed to normal then mostly after shaking or closing/opening it started being green again.
When connecting to external monitor - the colors are OK, so it looks like LCD or data cable issue.
I've tried hardware test and resets - no help.
I've tried to open the back lid and disconnect display cable from the motherboard, clean it and the connect back - nothing. I didn't dig deeper opening the display and trying to check the other end of the data cable, cause it seemed to be too complicated and dangerous for someone without good practice.
Is there any chance for this issue to be cable related, or changing the screen is the only way? Changing the screen is kinda not making me happy, thinking about the prices (where I live it's really expensive)
crwdns2944067:06crwdne2944067:0
Could you please post pictures here and/or upload a video on youtube of what is going on? Is the color changes just on certain area(s) of the screen or the entire screen?
http://s4.postimg.org/xqpor8665/Photo051...
The color changes in different places. It looks like on this picture, but it depends on the content on the screen. Wherever there's pure black color it becomes green. Darker tones, close to black will have some artefacts, like flickering green lines or something like that. When i drag some icon over the display i will see color distorted shadow (which is I suppose visual shadow effect, and it gets distorted because of darker tones it creates). I have asked couple guys, one of them worked for apple, another is actual worker of some non-authorized service center. One said "change the LCD", another "change the video card". Another guy just told me "it's useless, leave it and get used". They all didn't see the actual laptop, just got the same description of the problem as i provided here:)
Sorry, picture's horrible! Picked the wrong file from the cellphone:) But it's actually like this
In my case (Macbook Pro 17 late 2011) the issue is green artifacts on display edges and shows up in dark areas of pictures/video. I diagnosed it to likely a case of failing Graphics Multiplexer GMUX chip on the motherboard , likely solder balls losing contact underside the chip. I do not see any issues on an external monitor, only on the LCD.
If I use the 'gfxCardStatus' app https://gfx.io
to force Integrated (Intel) graphics (external monotor not possible in that mode) then the LCD displays perfectly fine. But if I select Discrete graphics (the AMD GPU) then the artifacts are back on the LCD.
People say pressing on the MUX chip (square chip on right hand lower portion of the motherboard with laptop bottom side facing upwards) may alter the artifacts shown or have them disappear.
When used standalone without external monitor a decent workaround on my laptop (unless GPU performance is badly needed) proved to be using the mentioned gfxCardStatus app to force Integrated graphics.
i have same problem
This could be a hard one to diagnose the actual cause without removing the LCD panel. I am of mind that it is a faulty LCD.
Cable
The cheap easy way to check if it is the LVDS (video) cable: With the laptop on, while viewing the screen. Move the upper half of the laptop, the part with the screen, toward and away from you. Does this cause artifacts (things that shouldn't be there) to appear on the screen(like the green flickering shadow) There may be color changes too. The video controller board on the back of the LCD could flex while moving the screen, if it has bad solder joint(s), it may show the same symptoms during the screen movement. However, in general if it is the cable you most likely will find one or more angles where the screen has a perfect picture.
LCD
From what I can see this could be caused by solder joint(s) on the LCD controller/column/driver board, compromised/broken from the vibrations/shock related to the fall. I lean towards this being the problem. From the picture you provided it appears the problem resides on the whole screen and not any particular area on the screen. However,as Dan stated with different words; This also could be caused by a TAB fault: See Cold Start here.
The material and the design of these is not very friendly towards diagnosing the cause of the problem without removing the front glass over the screen to be able to access the LCD. You may consider removing the front glass for further testing and increasing the repair options Here is one video showing how to replace on the LCD. It does not do a very good job of demonstrating how to remove the glass. Here is an excellent video on the entire procedure but, is quite lengthy. Here is a tutorial written on the subject. Replacing the LCD is cheaper and easier than the whole display assembly, even if you have to replace the glass too. Here is one source for the LCD. Here is one source for the glass. Back on topic: After the glass is removed you can apply firm (not overly) constant pressure on the front or the back of the metal frame around the edges/screen of the LCD, if this resolves the problem - at least while the pressure is applied, you most likely have a TAB (Tape Automated Bonding) fault. The TAB connects the transparent electrode layers to the video driver board (Driver board to the glass with the Liquid Crystal Diodes.) of the LCD. If such is the case the LCD needs replaced.
If pressure does not make this go away, then the problem is most likely a bad solder joint on the column driver/controller board attached to the LCD. The controller board can not be replaced without destroying the TAB. The board can be repaired by any electronics/TV repair shops that work on LCD TVs, for less than the price of replacing the LCD.
crwdns2886500:0Replace a glossy or anti-glare display panel compatible with the A1278 Late 2008, A1342 Late 2009 to Mid 2010 MacBook 13" Unibody models and A1278 MacBook Pro 13" Unibody model laptop. 1280 x 800 pixel Resolution. 13.3".crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Pro 13" Unibody LCD Panel
$69.99
wow, thanx for all the details! I'll try to figure it out. Hardly can do it by myself, better find some handy and experienced technician:) To much possibilities to damage something. But at least the cable I guess I can test:)
Thanks for the info, I had the green shadow too and took your advice to move the screen. It worked!!!
I'm having the same issue with my 13" late 2011 MBP, screen turning everything true black into a screaming green. Problem comes and goes but is there 60% of the time. I'm leaning towards a bad cable/solder joint/connection due to problem sometimes going away when wiggling laptop around. How would one go about changing the LVDS cable - is it doable at home?
Same problem with my 2009 MBP, although i did not drop it. I started having issues right after i posted a Mac For Sale ad on Criagslist, ha...Black images turn green but temporarly goes away when I apply pressure underneath the laptop, under the Command key area. Rumor has it, its caused by overheating from using on bed or sofa blah, blah, blah
b boy, this is the same symptom i'm seeing, with the pressure under the command key alleviating it. Did you solve this? what was your fix?
I didn't solve the issue, but I did do a trade-in at Best Buy for a $550 gift card & purchased a new overpriced MBP. Good luck
Same issue, the pressure solution kinda works. In my case was over heating :( @bboy if you are still around, did you have to change the screen in the end??
@bboy
Wait your fix worked on my 2010 mbp that is also experiencing the same issue. But how does it work?
EDIT:
See: Display, flickering green lines
Likely due to a gpu issue. And pressing helps to connect the parts together
Sorry to say you damaged the logic on the edge of the LCD panel. What happens it the connections along the edge of the glass get damaged from the bang. Nothing here to fix, time for a new display assembly.
Follow this IFIXIT guide: MacBook Pro 13" Unibody Late 2011 Display Replacement if you're up to doing it your self. If you haven't worked on laptops before this maybe not the best project to start off on. Do you have a local Apple Store or Apple authorized service center?
axisofedge crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 81,089
