need to buy logic board
MacBook Air "Core 2 Duo" 1.86 13" (Mid-09)
do you know where to buy logic board?
Serial number: W89420VN9A5
Logic Board P/N's:
  • 1.6 GHz (661-4589)
  • 1.8 GHz (661-4644)
You'll need to Google to locate the nearest source
crwdns2944067:07crwdne2944067:0:
what do you mean?
I live in GReece :P
Use the Google search engine or whatever search engine you use. Search for the part number 661-4644.
ok i will probably buy from you guys...
one more help please
how can i have access to my files? cause its not sata the hdd is something diferent
thanks
http://images.anandtech.com/reviews/mac/...
this is how my hdd look like
These smaller drives are different than the more common 2.5" & 3.5" drives we normally see. Apple used a drive with a ribbon connector setup. Can you explain what you need to deal with this as you had stated you needed a new logic board. The HD just plugs back in to the new logic board.
crwdns2934275:02crwdne2934275:0
As long as your changing the Logic board why not upgrade to the 2.13GHz board. Mid 2009. they are interchangeable. This will give you a better computer when your done. Make your money count. I would look on Ebay for a logic board. Be sure it is fully tested as working before buying one. As alot of people tend to sell off the old Ones they took out of their computer that were No good. Cost should not be over $225. plenty of guides online as to how to install these. Hope this helps.
could you please post some links to buy logic board?
thanks and merry christmas
The obvious place to start is right here at iFixit:
MacBook Air 1.6 GHz (Original) Logic Board
MacBook Air 1.8 GHz (Original) Logic Board
MacBook Air 1.6 GHz (Late 2008) Logic Board
MacBook Air 1.86 GHz (Mid 2009) Logic Board
MacBook Air 2.13 GHz (Mid 2009) Logic Board
Your serial number confirms that your computer is a Mid-2009 Macbook Air, so you should really stick with logic boards from that generation (1.86 GHz/661-5197, 2.13 GHz/661-5198) for best compatibility.
If the prices for the iFixit boards are out of your range, you can try the online auction site eBay as jeffhogancamp suggests, or use the part number as a search term in the Google search engine to find a retailer closer to you, as Dan and mayer suggest. This method is no different from Googling for anything else; you simply use the part number as the search term.
Parts from iFixit have been tested, and come with a replacement warranty for parts that don't work. Other sources may not check their parts as carefully, or offer any warranty at all. You should check the terms of the sale carefully before you buy. All these logic boards are used, so a warranty is your only real protection against paying for a logic board that's just as dead as the one you're replacing. A warranty is only as good as the seller who gives it to you, so pick your seller wisely.
As for installation guides, the logical one to look at is iFixit's replacement guide.
MacBook Air Models A1237 and A1304 Logic Board Replacement
What's wrong with the old logic board that you need to replace it? If we have more details on the problem, we may be able to suggest less expensive solutions. For example, you can often recover from a liquid spill by washing the logic board in purified alcohol.
crwdns2886500:0Replace a 1.6 GHz logic board (motherboard) compatible with the Original MacBook Air 13" laptop. Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Air (Original) 1.6 GHz Logic Board
$59.99
crwdns2886500:0Replace a logic board (motherboard) compatible with the MacBook Air 1.8 GHz (Original) laptop. Includes 2 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
$69.99
crwdns2886500:0Replace a 1.6 GHz logic board (motherboard) compatible with the MacBook Air 1.6 GHz or 1.86 GHz Late 2008 model. Includes 2 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
$59.99
crwdns2886500:0Replace a logic board (motherboard) compatible with the Mid 2009 MacBook Air 1.86 GHz. Includes 2 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
$99.99
crwdns2886500:0Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Air 13". Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
MacBook Air (Mid 2009) 2.13 GHz Logic Board
$99.99
Don't do it, all of these are junk and close to death. And there are no newly available MCPs available for them. This is of course assuming that the hinges on your laptop outlive the MCP on the 6 year old board you are about to buy. Take it from my experience this will just end in misery.
like what from where?
themis1983 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 869
