This versatile wireless broadband router released by Verizon in 2006 supports Ethernet and Wi-Fi networks.
Why is my internet connection slow?
When I go to load a web page, it loads very slowly or even doesn't load at all. After checking all the connections to the computer and router, everything is connected properly. Why could this be?
You might want to consider if any other electronic devices are interfering with your internet connection.
If your other electronics are working on the same frequency as your router, your webpages could load slowly. Make sure that you keep other electronics like cordless phones and microwaves away from your router to help it work efficiently.
If this trick doesn't work, you may want to check the device's Troubleshooting Page for additional advice.
To piggy back on Jeffery Fox...I had similar issues and called my provider after trying sites like speedtest.net and found my connection was not up to snuff. Then we logged into my wireless router and discovered that a number of my channels were overused by other wireless systems nearby so we tested a few and tried the speed test repeatedly to pick what worked best. Occasionally, I have found a reset of the wireless modem helps refresh things to. Your mileage my vary...
Internet speed test at: https://speedtest.19216811wiki.com/
James Carby crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 379
