Verizon M1424WR router won't turn on
Wireless router has no power.
Power connection missing
Without a power source, the router will not turn on. Confirm that the power cord is connected to the power source from the wall and then to the router.
Damaged power port
If the port on the router that receives the power is damaged, the router will not turn on. Make sure that the power supply is working correctly, and if your router is still not powering on, then you will need to replace your power port.
Slow internet connection
Internet web pages and downloads are loading slowly.
Interference
Electronic devices like wireless phones working on the same frequency as the router can interfere with the internet connection, causing slow internet. Keep these devices as far away as possible to try and eliminate this interference.
Cables are inserted incorrectly
If any of the cables going into or out of the router are inserted incorrectly, then a weak internet signal may arise. Make sure that all of the cables are fully inserted and that you get a distinguishable “click” when inserting them.
Antenna is broken
If the signal is weak, it could be resulting from a broken antenna. If this happens, you will need to repair the antenna.
Firmware is not up-to-date
In many cases, the slow connection from a router can be corrected by updating the firmware. The latest version of the firmware must be downloaded followed by resetting the router.
Some LED’s wont turn off
Once the device is powered on, all of the LED’s should light up for a short period of time. Then the LED’s that are not being used should turn back off. If all the lights stay on, then there may be something wrong inside the router.
Factory settings may need to be restored
If there has been any change to the router's default setting, it could cause the LED’s to stay on. By resetting the router back to normal factory settings, the setting that deal with LED’s will be restored back to the way they were when the router was new.
LED’s do not turn on when Ethernet cable is plugged in
When the Ethernet cord is plugged in, the LED’s do not light up as they should.
Cables are not inserted correctly
In order for the LED’s to light up, the connection must be correct and secure. The distinguishable clicking noise should be heard to confirm that the cord is correctly connected.
Power source is not functional
If there is no power coming from the source, then the LED’s will not light up. If the power source is not sending power, then change to an alternate power source.
LED's are damaged
If the LED's still do not light up when connected to a functional power source, they may be broken.
James Carby
crwdns2935283:009/17/14crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-3, Mathis Fall 2014 crwdns2935289:0University of Kentucky Louisville, Team 1-3, Mathis Fall 2014crwdne2935289:0
LOUISVILLE-MATHIS-F14S1G3
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 5,687
