iMac 17" Works perfect only on Safe Mode
Picked up this White Imac 17" for $20.00, seller said Imac was dead....first boot went to screen with some artifacts and then it freeze. Try resetting PRAM and SMC...still same effects, I booted into safe mode and everything works perfect, no issues whatsoever, rebooted to normal, same issues as before. I figured that maybe a bad driver, so I started loading OSX Lion from my USB drive, everything looked fine during installation, no artifacts whatsoever, but when the final reboot to enter for the first time, back to artifacts and freezing....any help would be appreciated.
crwdns2944067:012crwdne2944067:0
Can you give us the last three digits of your serial number so we can correctly identify which model you have.
VUX is the last 3 letter of the serial, the bottom plate shows to be 17in/2.0ghz/1GB/160/SD/BT/AP. EMC # 2114
From EveryMac: This system can run the last version of OS X 10.7 "Lion" if upgraded to at least 2 GB of RAM. Although it has a 64-bit processor, it has a 32-bit EFI and is not capable of booting into 64-bit mode. It does not support "OpenCL"
I would still try Snow Leopard Vs Lion
Hi Dan... Thanks for your fast response... I did upgrade to 2GB RAM... Im installing Leopard into it as I write this from my ipad... Will let you know the outcome
crwdns2934275:07crwdne2934275:0
I think you'll need to locate a copy of Snow Leopard (10.6.8) as this model does not support 64bit mode. Give that a try.
If this answer answered your question please remember to rate (score) and mark it accepted.
chrisimo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 460
