AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Where do I solder the two wires?
I have a typically frayed magsafe charger. It frayed at the end and became useless so I replaced it. Since I have been getting better with a soldiering iron, I deciede to take the razor knife and cut into the plastic part to open it up and see if I could Frankenstien it back together.
Guess what? It worked!!
You've heard "if it ain't broke, dont fix it." Yeah, well I decided not to follow that advice because I wanted to make it look pretty.
Murphy's law kicked in and it won't work any more.
Which wire goes on which soldiering point of the tiny PCB under the plastic cover? One goes opposite the chip, and one goes other end but I am unsure of myself since I messed with it too much. I de-soldered everything and I am starting with clean wire from the brick.
There is the inside wire and the outside wire and I need to know where each one goes.
Or did I fry the PCB or chip or whatever by heating too much?
Thanks in advance for the responces.
Frank
A picture would really help explain this.
I was able to answer my own question and in the process I wrote a repair guide. I took photos of what I was doing when I did it then i forgot I took them. So I am at once goofy and a genius.
Good job on the repair and thanks for providing a guide! Welcome to iFixit.
Somehow I missed this back in June while I was traveling for the iPhone 4. Great job!
If you are careful, you can slide the little white cover off the magsafe connector and up the wire, instead of cutting it off.
040304 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 11,033
