Modern rebirth of John Cooper's classic automobile, made by BMW.
Cabin air vents not supplying any air.
I own a 2004 Mini Cooper S, and no air will come out of the dashboard air vents. All air seems to be vented through the defrost vents. I have checked all fuses, cabin air filter, and even tried the "off button/ '+' " system check with no faults found. Any suggestions would be welcome.
crwdns2889612:0crwdne2889612:0 -1
Most cars have either a cable or a motor system to alter the air dampener valve/s.
When you alter the setting do you hear any noise of a motor or the thump of the valve closing? My Ford had foam rubber as a seal around the dampener door it got sticky so it wouldn't open.
You may need to locate the valves under the dash heater/cooler box. Try moving them manually.
Jay crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,443
