Per this guide I found online the CMOS battery is indeed soldered to the logic board Toshiba Satellite Pro L450, L455, L450D, L455D disassembly. And, here's the location from the guide: CMOS Battery for reference.
With a desolder pump and/or solder wick you should be able to remove the solder to remove the battery. But you will need to completely remove the logic board to get to the other side to complete the desoldering and reshaping the legs so they can pass though the logic board (be careful you don't damage any of the neighboring components or traces in the process).
Once you have it out see if you can identify the battery. If you having a hard time paste a good collection of images of it so we can see the markings and if you can place a ruler beside it so we can see the size (height & width).
Without replacing the battery you will encounter system reset issues as you have noted. While this is not a hard job to do it does require a lot of work. Do you have the right tools and work area (proper ESD protection). If not you might want to find a local repair shop.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
