Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
screen became a bar code
i went on a walk in the texas heat but it only reached up to around 70-75 degrees and then as i git home i pulled out my phone, that was placed in my back pocket, and i noticed my screen had turned this redish to grey screen that had vertical lines going down the screen making it look like a barcode. Help please i really dont know what to do
and the screen works prefectly fine i have a video of it you can see a little part of the working screen please someone help
In the back pocket you may have damaged the lcd. I would try a Home+Power to reset the phone. If that doesn't work, you can try powering down, lifting the glass and re-seating the cable connections. Also, from what you stated, it is plausible that when you sat down there could have been a coke can, or anything behind you that could have spilled into the phone and dried out without you even noticing (but, in that case I would suspect many more issues popping up).
If none of the above works, order a new screen and give it a try. But, honestly, when I typically see a white screen AND banding, and reseating the cables doesn't work, 99% of the time it's a faulty lcd (or in the case of replacing the screen a cable accidentally gets crimped/damaged). :(
Same problem I'm going for a screen replacement
Alyssa crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,448
