screen hinge loose tilts
Is possible to tighten the iMac screen hinge without completely dismantling the computer. some claim a plastic card pushed in above hinge with release a clip allowing asscess to torx screws ?
Any news on this?
I made a fix for this. www.themachack.com
Simple solution: A rubber crutch tip placed between the monitor and the stand holds the monitor position securely and can be very easily adjusted in about 5 seconds. Cost: $0.29.
Simple fix: A rubber crutch tip to support the screen is infinitely adjustable. Mine has been in place at least six months with absolutely no problem.
Yep,worked a treat
THANKS
What is a rubber crutch tip? Is it the piece that goes at the bottom of the pole of crutches? I’m trying to imagine how that would work.
The newer iMacs have a newer foot design.
Your idea of a plastic card was the means to gain access to the foot screws to replace it for a VESA mount on the early '12 and older units. Sorry won't work here.
Here's some background: iMac 27" stand removal.
Given the age of your system I would try going to Apple for repairs.
scoot crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 14,066
