Why does my printer suddenly says the toner is not compatible?
I've been using my Samsung SCX 340 printer for a year and half and last week, it stopped printing.
I got this error message : "Not Compatible Toner cartridge" whereas I had been using the toner cartridge for a while already but it wasn't empty.
Do you know what could have gone wrong?
Many thanks,
Estelle
crwdns2889612:0crwdne2889612:0 18
crwdns2944067:016crwdne2944067:0
To determine if it is the printer or the cartridge, try a new cartridge. If it works, you know that you have a bad cartridge. If it does not work, your printer has communication issues with the cartridge. Let us know what you find.
i have a same problem in samsung scx-4521fs "Not Compatible Toner cartridge" what can i do i repast a new toner but i get the same problem
toner cartridge is not compatible
what can i do
Samsung blocks the use of third party toner with software updates!
I am an American in Egypt with a Samsung scx 3405 acquired locally and had my family bring me a legitimate new cartridge bought at Office Depot as the one in the machine ran out of ink. It turns out that American cartridges can not work on SCX 3405 models made outside the US. Stupid!!!
crwdns2934275:011crwdne2934275:0
crwdns2933315:016crwdne2933315:0
Hi,
Try this: Power off the printer. Remove the power cable for more then 10-15 min. Remove the cartridge. Check it well. You must have a small board with golden pins on it (usually 4 pins). From this place the printer communicate with the cartridge (in the cartridge you have a small board with a memory i.c).
If this not help you'll need a specialist. The problem can be in the printer and/or in the cartridge (more probably in the cartridge).
Regards.
Thanks for your help. I tried that. I also thought that the problem came from the fact that I was using a refilled cartridge and not an original Samsung one.
Therefore, I purchased a Samsung cartridge. I could make 2 copies but the error message reappeared.
Bad news. :-( You must go to a service.
my printer photocopy supporting but letter file is not supporting but why ?
Hi guys!
I had the same problem with my Samsung CLX-3185 but I finally FOUND THE SOLUTION!!
Someone mentioned that it might have had to do with the receptors (the four golden pins) on the toner cartridge, and I thought that might have been the case since all four of my other cartridges were working just fine but the cyan one just kept coming back with that error message.
This is what I did. I simply took the cartridge out, used my shirt to clean the golden pin areas as well as my fingers. Gave it a good rub, and then shook it a little put and put it back in. Then it instantly started printing again and the error message was gone!
Side note: my toner cartridge was a refillable one, and not one from Samsung as well.
This worked wonders for me and finally resolved my problem!! It was that simple. Hope this helps everyone else :)
Just fixed the same issue on my 2165W by thoroughly cleaning all the terminals and rollers with methylated spirits. My refillable cartridge is now recognised as full :)
Abundant thanks! It worked for me too! I gently cleaned the contacts and blew. Out camea fluff of dust. Tested to print and it printed! No error message appeared. Great. Many thanks Nester!
I highly recommend using a soft lint-free cloth/material for this. Otherwise, some lint may get onto the connectors or inside other areas causing additional issues, even if you don't see the lint.
I also recommend using isopropyl alcohol in this application. Here is a link explaining why. https://www.chemicals.co.uk/blog/isoprop...
This just worked for me !
Samsung M38870FW printer with a new £20 aftermarket cartridge that I was about to return.
Many thanks for posting
You have indeed #SOLVED it for me.
Mario London UK
Cleaned the pins with ROR - Residual Oil Remover - which is used to clean photographic lenses and filters. Problem just disappeared. Thanks!
BOYCOTT SAMSUNG. They sell you a product that works with various cartridges and then break your printer when you do.
Samsung’s printers department was sold to HP. If they still with the Samsung’s name, i don’t know! Now HP “invent” a photocondutor, only for complicate this.
I have the exact problem, my ML 1675 V 3.11.34.00:08v (I presume thats the driver) I added paper and it didn't start again. I have the correct cartridge as it worked a minute b/4 I added paper. Tried all these things no go, called Samsung support they were very helpful... tried the same things as I had prior to the call still no go.. bottom line was I was advised to go to their website and BUY a new printer. I thought that was nice, I know this one wasn't expensive (a cheap-o) but it served my purpose and with only approx 250 sheets used I am a little peeved off. Don't have it repaired unless it was very expensive. dumped it.. go buy another brand..
I can't tell if you have an ironic, mocking tone in your voice or not. Was Samsung really helpful, or not? I wouldn't think that buying a new printer would be the solution here. At minimum I would think they would ask you to buy a new cartridge. Cheap printer or expensive, they all generally work the same way, it's just a matter of how many bells and whistles are added and how high the print quality is. This sort of thing !#^&@! me off, as I have had a good black cartridge for months now and only after exchanging the magenta and cyan did I get this stupid message from my printer. It's too fancy and expensive to just toss out.
@David Meyer
Sad thing about it is when I spoke to HP support about my Samsung printer that will no longer recognize 3rd party cartridges after inserting ONE Samsung cartridge. The tech told me that after inserting the Samsung cartridge, that cartridge sends data to the printer which tells it from that point on, not to recognise any other cartridges if they are not original Samsung cartridges. I asked him how is that even leagal, and he replied that it's not. ??? That'll teach me to ever use OEM cartridges again. My printer was working fine with 3rd party cartridges before I used the Samsung cartridge. The nerve of them to install something I didn't ask for on my printer that "breaks" it, is just not acceptable. If I had the money I would sue then for a monopoly violations and forcing you to use their expensive cartridges and ONLY their cartridges. (I'm so !#^&@@ off right now)
I had the same problem. Turned off power and disconnected pwr source. Replaced all toners with new (not original), waited 15 minutes, turned on again and it all worked .
worked for me as well with Samsung scx 4729FD
I had the same thing happen with my Canon PC940 copier. One day, copies were great, the next time I used it, they looked like the toner had run out. I live in an area of high humidity so I suspected that the toner may have clumped together. I put the cartridge in the oven at 150-175 degrees for two hours and, voila, everything began working again.
That's not "the same thing" at all. This thread is about a Samsung printer's evil efforts to reject a working toner cartridge with a "We disagree with your rights, therefore your toner cartridge is incompatible" message and a refusal to print on political, not technical grounds. Your message, on the other hand, is about a different manufacturer's printer having trouble with its toner, and your interesting solution of baking it in the oven. That will not fix the Samsung problem here unless you accidentally clean the contacts in the process.
Firmware for the printer was probably upgraded along with your drivers. All the new drivers make anything but Samsung toner incompatible. If you have the original installation disk, delete the drivers you are currently using. Use your original installation CD ROM and reinstall the original drivers.
Can any one have old drivers that comes with printer model scx 3401 so too can avode updation issue for refill toner cartridge. Send link or pl. Upload in google drive.
I have re-installed from the original disc but still getting same message and wont print anything.
I have the same model of printer but I have never had such problems.... Have you ever replaced the toner? Are you sure that you bought the right model or was it qualitative enough? It is very important! I have seen here hardware.be/printkop/brother a lot of toners for almost all printer models but I have never tried it. Although the reviews of this shop are positive. Have you ever tried it?
I have the Samsung M2875FW. It takes cartridge #D116L.
I had the "toner not compatible" message on the printer and it would not print. What I did was unscrewed the plastic piece containing the little circuit board with the four contacts. This plastic piece covers the entire rear face of the toner cartridge. Once you remove the two screws, it easily unclips. I then replaced the plastic assembly from the defective cartridge with the one from my working cartridge that I was replacing.
Be careful while doing this not to mar the black roller on the front of the cartridge.
After doing the above procedure, the cartridge was recognized and printed perfectly.
Brilliant advice.
I had unfortunately used once an imitate cartilage, which was poor quality and leaked a lot.
But than my printer rejected afterwards the original cartilages, saying they were non-compatible.
The fake however worked.
So the manufacturer of the fake ones had even manipulated the security measures. A pop-up of his store appears, when cartilages run out.
So I did the same: changed the original cartilage chip to the fake chip and now it works again, also of course it reads that the toner is low.
In the electronic shop the serviceman for the printer had advised me also to throw the printer away and buy a new one.
But what a criminal store manufacturing the imitates!
We bought a toner about 5 weeks ago. The two red lights are coming on and we can't print. Some ink is coming out.please advise
hi, what I will like to no what kind of ink or toner name and code so I can help you.
I would suggest buying a new cartridge. If it is indeed toner, please leave the printer outside as it may be toxic to people due to the sillica contained. If it is ink, oh boy do you have a lot of cleanup.
Try going onto the Samsung window and search for more printers. The Samsung always keeps changing it's compatible code, which is very annoying. The code should be something like 192.168.1.20. I had that compatibility problem myself. The 192.168.1.68 wouldn't work, so I used the 192.168.1.70. When that wouldn't work, I used 192.168.1.72, then I used 192.168.1.66. Finally, when THAT wouldn't work, I used 192.168.1.73, but that is subject to change. Hope this helps.
But those numbers are not likely relevant to your printer because I use a different model. The Samsung window will help because it auto searches for the compatible code.
hey @oldturkey03 can you remove the IPs? thanks!
Vincent,
hi
what you have to do you have to put another cartridge and see if it will tell you not compatible again .
The course of not compatible it can be (MICRO-CHIP on the cartridge or firmware updated).
Unforunetely the only thing I could do to fix it is use theirs now. Sadly, I think their may have been an update on the software and it recognizes the generic one. Their ink does look nicer but it does stink how much more it cost.
I have samsun scx - 3405f the toner was finish and I buy the new toner same model after I have install it , it say the toner is not compatible for printer. I need help for that problem pls
I have 2 x samsung Xpress M2020w , one will use the toner I have the other says its not compatible with the same toner?
thanks
The printer that is refusing to accept it is at a higher Samsung software revision level than the printer that accepts it. Because Samsung apparently under took this intentionally, I acquired a Xerox printer to be my longer term solution. I will use the Samsung printer only until the toner that I now have, runs out. I had to throw away A couple $100 worth of toner because of this software upgrade.
My solution once I finish using the existing genuine Samsung toner cartridges that I was forced to purchase at an outrageous price, is to junk the Samsung and, since HP is the owner of Samsung at this point, I will absolutely ignore any HP offering and instead will purchase a Xerox or Canon as a replacement laser printer.
Estelle Lafforgue crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 305
crwdns2942667:0crwdne2942667:0 129,213
