Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
crwdns2934591:073crwdne2934591:0 crwdns2934593:0crwdne2934593:0
crwdns2934055:0crwdne2934055:0
Replaced LCD, only get a backlight?
Hi,
My Ipad 2 2012 got pretty smashed up, i dismantled and the parts i needed were digitiser, lcd screen, power flex ribbon and headphone jack ribbon (runs from power flex and goes into logic board)
I have put it together and tested it and with the ipad plugged in i can see the backlight, i can also see it working when i try sticking it in dfu mode and recovery mode.
restores will not work as i keep getting errors (21,3194,3004) but it is being recognised by itunes.
does this sound like a hardware issue or software issue?
Sounds like both, the backlight issue could be the result of not turning off the iPad before disconnecting the digitizer and LCD. That's called perm dim. It requires changing a chip and coil and intricate solder work. Did you try a hard reset? Holding down the menu and power button at the same time?
Tried that, by the time I got the parts to do any work on it the ipad
Had lost all it's charge, how can I inspect to see if this is the problem or
Is the only way to tell to replace it?
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 150
