The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
crwdns2934591:0299crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Is the rear camera the same as the Ipad mini?
Hey im trying to replace the camera on my ipad air and i cannot find one that is reasonably priced. I have found that the ipad air and the ipad mini's camera look exactly the same and have the same specs. should i try to buy one? what is the model number the camera for the Ipad air so that i can compare to the ipad mini?
The original iPad Mini and the iPad Mini Retina use different cameras. The iPad Air and the iPad Mini Retina share the same rear camera - part number 821-1521-A. The original iPad Mini uses a different rear camera - part number 821-1521-06. I'm not sure what you consider to be a reasonable price, but you can find the correct part here.
Update
If you check this image, it appears that the bracket on the camera is different. But upon closer inspection, I think that the bracket pictured is only held in place with adhesive. Good catch! Thanks!
crwdns2942205:01crwdne2942205:0:
Thank you for you post and the link! but i have a correction for you. according to the link provided the camera is for the Air, mini, and mini/retina. but your did answer my question and i thank you very much!!!
Hitordie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 325
