Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
On what part of iPhone 5 is stored info about Apple ID
On what part of the iPhone 5 is the Apple ID information stored? I want to know what chip or part to remove in order to would remove all info about Apple ID (to get past the iCloud Lock). Would changing the Logic board (from an iPhone without the lock) remove the problem? Is there any other way to unlock such an iPhone? Thank you!
crwdns2889612:0crwdne2889612:0 43
crwdns2944067:045crwdne2944067:0
If your phone is locked you either have a stolen phone or someone who has access to your account has locked your phone. At this point you'll need to go to the Apple Store with iron clad proof you are the owner of the phone for them to unlock it. Otherwise you should return the phone to the rightful owner.
I asked because I wa thinking to buy one of those very cheap iPhone 5's from ebay that are locked from iCloud. My idea was to buy one that's locked and another unlocked logic board. Put it in and have working iPhone 5 for very little money. + I clould get one that's from verizon and has bad ESN(even cheaper) and use it here in Europe on GSM. Do you think changing logic board would fix problem?
These are likely stolen units someone is selling, I would recommend you stay away from buying them.
It is just and idea, I don't I'm going to do it. But still I'm verry intrsted if what I described above would work. You would help me a lot more if u can just answer.
By the way if device is locked from iCloud that's NO WAY a sign it's been stolen. It happende to my friend he forgot pass for he's Apple ID and email inbox he used for it. So those thing do happen
You should re-read what I said - I stated it was likely a stolen phone not that all locked phones are stolen as I also stated someone who had access to the account could lock your phone and I suppose if you fail to pay Apple for your iCloud account you will loose access to it as well. But that doesn't lock your phone only the server account and the access to the data on the server. Your friend has either twisted things around or has another problem. Your friend will need to visit Apple with phone in hand with proof he or she is the owner of the phone for them to unlock it. As for the eBay phones you can't prove you owned them so they are of little value as a phone. If they were stolen (most likely) you would have bought nothing but trouble.
crwdns2934275:040crwdne2934275:0
crwdns2933315:09crwdne2933315:0
There is no point doing this. It will cost more than buying a legal one.
The iCloud lock information is tied to the phone's IMEI and stored on apple's server. You have to replace the baseband and the baseband flash memory. But doing this is extremely difficult and will likely break the cryptographic pairing between chips, causing activation issues.
crwdns2889612:0crwdne2889612:0 17
crwdns2944067:022crwdne2944067:0:
That's not true. I can get working iPhone 5 with locked iCLoud for 180$, and I can get logic board from broken iPhone that was activated for 50$. So that's 230$+ some work (I already have the right tools). I know how to change logic board, I did it before.
IMEI is stored somewhere on logic board. right? So changing the board would change IMEI with activaed one?
I don't need to change seperate chips, I'll chabge the whole logic board-Way Easier.
I just want answer if changing logic board with locked ID with one that's activated will give me activated iPhone that's all.
Only the logic board matters,the rest is not expensive and not related to security
The phones serial number won't match so it will be suspect. Many carriers are now tightening down as well as Apple (they require both IMEI numbers when exchanging logic boards for their database) to activate mismatched phones. While you may think your getting a good deal here all you're doing here is putting a spotlight on your self as someone who either stole or accepted a stolen iPhone (possible jail time).
@Tom Chai So that means it would work?
@Dan Suspect for who? I don't need any carrier to activate my phone, I'll get activated one.
No way I'm put spotlight here where I am...
I agree, 50$ for a not locked, functioning iphone 5 logic board is suspicious as !@#$. In China the trend is around 2000 CNY which is more than 300$. Even with that price, nobody guarantees the board is not taken from replaced phones or registered with icloud. Anything cheaper than that probably gets you into trouble
crwdns2934275:017crwdne2934275:0
nand flash+baseband proc+baseband mem = and you got working phone
Update
crwdns2889612:0crwdne2889612:0 25
crwdns2944067:026crwdne2944067:0:
just wondering did it work?
try it and you will see ) if you have years of expirience with resoldering chips of course. otherwise you never make it work, this is very complicated job
Basically brain surgery ;-}
hi,
those 3 chips that need to be changed, they have to be pre-programed right?
They must be removed from working board and installed on the board that have icloud. You can not programm those chips myself.
crwdns2934275:021crwdne2934275:0
Yes very possible in fact did it today. If its your first time working on an iphone, here is a little hint I wish someone told me 3 years ago. GET A PAIR OF 3X READING GLASSES from the dollar store. It will save you so much grief.
Anyway, tried to re-solder chips once to get my daughter a 4s, big pain in the a$%!. It does work though.
My opinion on Apple's Activation lock- It is scam on Apple's part. The majority of Activation locked phones are NOT stolen. Now ther are millions of worthless (unless you are tech saavy) phones and Apple has a reason to produce and sell more phones. Hundreds of people waste money on eBay everyday buying phones honestly and get stuck with a paper weight. Apple benefits in the end.
Solution- ONLY LOCK PHONES THAT ARE REPORTED TO POLICE AS STOLEN. Not every freakin phone with iCloud on it. Come on!!
crwdns2889612:0crwdne2889612:0 19
yes it works and I totally agree with Chipper
Ma Apple služba za korisnike su ser..e! Znaci kupio sam iPhone 14pro zaključan ,telefon je pripadao umrloj osobi,nije na crnoj listi,iCloud je privremeno on. Osoba koja mi ga je prodala je koristila telefon dok je imao energije u bateriji i nije promjenio zaključavanje zaslona šifru. I kad se mob ugasio eto problema. Njemu je 1godinu stajao u ladici a mob ima 30 ciklusa punjenja,kupljen listopad 2023 radio 1mj. Zaključan od studenog 2023. Pitao sam Apple za pomoć,objasnio situaciju,i dali su oni meni broj slučaja i da posao preko iTunesa ako je radio prije ko da postoji mogućnost da opet radi.imam mfi kabel i došlo mi je ažuriranje novog softvera do nekih 99% i izbacilo me sa iTunes pokazujući grešku 75. A nebi oni pomogli jbt da čovjek može koristit mobitel nema teorije,iako je prvi vlasnik umro. Traže kopiju računa ili ostavi su di piše da ga je meni dao. Strašno. I sad vidio sam da slažu ljudi sami iPhone sa djelovima. Zanima me koje djelove mogu pustiti,tipa baterija,kmere... A šta kupit da mob radi
Just wanted to let everyone know this worked very well for me! I bought a phone that was in perfect condition with the only drawback being activation lock, and a shattered phone that did not work, but had non-activation locked logic board. I merely put the clean logic board from the broken phone into the clean phone and boom, the phone worked perfectly having all the contents from the shattered phone inside the clean phone. You will need certain tools to do this but those can be easily bought on amazon. Good luck!
crwdns2889612:0crwdne2889612:0 10
I have also same problem due to over heating some circuit lines and soldering have removed from the PCB . I thought to buy lock phone and then replace the three IC baseband, flash memory IC and third one I dodn't know any body can help me .
Just buy an unlocked broken phone with clean IMEI, switch the Logic board and you have an awesome working phone. then turn around and sell the parts of the broken phone on ebay...njoy
I have a brilliant solution but its not for the faint hearted or most likely the intelligent.
Get an unlocked iPhone and then get another locked iPhone, solder the unlocked chips off locked one and re-solder them on the unlocked one, now get other chips off unlocked iPhone and solder them on locked iPhone, WAIT.
Try again, get iPhone thats locked and get another thats unlocked now concentrate and stop messing around.
Desolder chips from perfectly good working iPhone 5 therefore breaking it and solder them on the other iPhone that is broken therefore making it unbroken.
Magic solution, pick up unlocked iPhone in left hand and now concentrate as this is very difficult part, pick up locked iPhone in right hand, put contents of left hand in right hand and contents of right hand in left hand now in left hand you have locked iPhone and in right hand you have unlocked iPhone.
(Some people are Otters, some people are Rocks)
Send more Otters, we have too many rocks now
One locked imperfect condition one that's inlocked got ran overthe original plan was to swap screens but once you get th open and screens removed you see a lot of differences even the battery's are different voltage and what not. The one is locked because it was lost. Can you swap parts over and what are needed to be swapped. Also I just want to add to the really dumb peranoid comments above. Apple does not have iPhone police nor will they ever. .Really this find phone function is pretty useless other than you can temporarily disable the phone. So I want to keep the parts that the screen plugs into on locked phone but everything to the home button I want gone and retro fit the unlocked phones parts that are different slightly but different non the less into the locked one thus making it nice shiny new and functional. Don't say I can't because I'm gonna just looking for some advice. I'm not techy I'm just a tile setter so if I'm doing this I know someone else has had to have done it. Thanks in advance now go!
To remove icloud from motheboard needs to be resolder 3 chips from any other motheboard that do not have icloud. (all info icloud,imei and other split by apple in 3 chips) this is why have to be change all 3 chips. For people who have expirience with soldering its possible for other not.
Update
Yep Dan (it can be done for sure) Do the same thing on iphone 4s, we will see how everything goes with 5s.
Update (10/22/2015)
www.planetrepair.com.ua
I posted rarely but i do.
crwdns2944067:016crwdne2944067:0:
Andrei - No one is going to go to this level of effort, nor do they have the needed gear to even attempt it. Bottom line here it's a dead board (phone).
Just out of curiosity, what 3 IC's are those?
Baseband, baseband memory and another one I don't know.
U601 if you chech schematic you will see this chip. I know Tom :) but at least people get the answer
Hi, Andrei, U601_RF is the baseband memory, so what else needs to be changed?
crwdns2934275:011crwdne2934275:0
Bro, if you read Russian here is some service http://digitalsphere.ru/services/1052032 (I am not affiliated with them, just interested in the same problem) check with them, there is also some part in English or you can use ggl translator.
forget about such service, dont waist your time and nerves here is tons like this and all this crap! waist of money and time....they remove maybe 1 icloud from 1000 )))))
Noone has answered the very simple question. If i replace the logic board does it restore to factory settings?
No......what ever is on the motherboard you are putting into the phone thats what you get. You can then restore it to factory setting if you want
I have iphone 5s clean without icloud.. but first its on red screen then i flashed it then it stucked on itunes logo and itunes error 4013.. and i also know the solution is that remove nand and reprogram it.. but my question is that if i replace the nand flash only from other unlock phone that will work or not??
blagojevic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 164,563
