The Lenovo G570 is a 15-inch laptop announced in January 2011.
crwdns2934591:023crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Some horiontal line is displaying in my laptop
I thought the reason might be due to loose connection to my laptop display. I tried to press my screen at corners but it does not works for me :( . So could you please tell what is the solution for this...
Horizontal lines are often LCD display problems with the driver chips and/or the screen got a hit on the edge breaking the fragile connections to the driver chips.
In any case the panel assembly will likely need to be replaced. You can verify this by connecting to an external display if the external display image is not distorted then you know its the LCD display.
Hi,
Try reinstalling the drivers for your VGA if that did not solve the issue you have to replace your LCD. You can search and buy for your laptop model LCD from eBay.
Good Luck.
Anjani crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 17,114
