This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
Low light or no backlight on LCD
I have an 27" LED Cinema Display and when i connect it to my Macbook Pro 5,1 and connect the power supply i can only see the display on very very low light, i have tried changing the resolution and the light in the system preferences
crwdns2889612:0crwdne2889612:0 13
crwdns2944067:021crwdne2944067:0
How does it work with other computers?
Hi.
i know your post is old but i have the same problems and and test it with success ...
1) down the luminosity to the minimum.
2) disconnect power and thunderbird cable.
3) connect power and thunderbird cable.
for me, is ok.
if you find the solution for my problems, dont hesitate to make a answer.
I have to say that Jeremy's solution also worked for me. I picked up a "no-display" 24" Cinema Display for $40 on the off chance I could fix it. Setting brightness to zero, unplugging, and re-plugging fixed it. Before that, you could only see graphics by shining a bright light onto the display. Thanks!
@sg1archive can u explain how did u fix it?
@sg1archive would you be able to show us? I did just bought one for $50 as well with same issue.
crwdns2934275:016crwdne2934275:0
crwdns2933315:015crwdne2933315:0
The backlight with this model is built into the LCD display assembly and draws power, through a separate backlight cable, directly from the device's power supply and depends on the logic board to provide backlight information.
Diagnosing the failure in this would require you to use a digital multimeter, set to DC, to check for 23.3-25.7 V between the chassis ground and the 24 V test point on the logic board. If no voltage is present then the power supply is likely bad. If proper voltage is present then you should inspect the LED backlight sync cable, which is attached to the back of the LCD panel, for damage and then reseat it. If the issue persists then the next step would be to replace the LCD panel or logic board, in either order since they are both costly components.
Hopefully that gives you something to go on.
Here is a teardown for the 27" Thunderbolt display, the backlight portions of the internals are very similar to your model.
crwdns2889612:0crwdne2889612:0 8
LikeARabbit: Could you indicate where on the logic board the 24V test point is located? I've got the same problem as the OP, and it's time to get my toolkit out.
Here's the logic board image from the teardown.
Hello All,
I did as "LikeARabbit " suggested above, and it worked for me.
I was having an issue of a very dim to complete shutdown of my Apple LED Cinema Display 27".
I opened the cinema display as per the instruction from the "Apple Thunderbolt Display Teardown".
The inside are almost the same as I have both and can attest to this.
I tested the power on the logic board that "LikeARabbit" suggested and mine was running a consistent 24.3 V on my digital multimeter. As to where to test this, please see attached photos. sorry for the bad quality photos, but I had very little time.
Since my power was within in range I made sure all the cable were seated properly by unplugging and replugging them one at a time. Do this with the power cord unplugged so you do not fry the boards, LCD, or yourself.
One plug I noticed right away was the "Function" plug which was very loose. I believe this is the LCD background lighting system as it istantly increased my brightness after reseating this cable.
After powering the LCD up, I moved this one cable around a bit, and sure enough, it was the one causing my issues. It is now properly seated and I have not had any problems as before. The LCD is working as it did when new.
I did create new monitor profile after this as I noticed the colors were off at this point. I am a photographer and need these LCD to match. with my iMac 27.
Below are the photos of the cable that was loose inside my Apple LED Cinema Display 27 and the two connections where I tested my power to the LCD backlight system.
I hope this helps.
Kind regards,
Johnny
I had the same problems. Backlight was gone or very low. The short story: I found out that the micro controller does not send the PWM signal to the LED driver. Very mysterious! I checked the LED driver components (Mosfett, diode), I read the data sheet to understand the function of the HV9982 (LED driver). In the end there was no hardware problem there. If I connected the computer the micro controller enabled the LED driver but "forget" so send the PWM signal, so the LEDs stayed off. Mmmm...maybe this is a software error or Apple wants to tell me to buy a new one? So I bridged the PWM input pins with a little wire connected to a 3.3 V pad (which I found about 1 cm around). Nice that die PWM output pins of the micro controller were bridged by 0 ohm resistors, so I could remove same and cut the connection from the micro controller. And then I got full backlight again. Of course I am not able to dim the backlight anymore.
Hi Michael, you have any pictures of how you did it, or can you guide me through it?
Michael posted a LOT of detail in another thread here: What components need replacing on the Logic board?
Hi, I had a similar issue however I think thar @likearabbit is correct, I displantled an old iMac 27 which had GPU gone and, I noticed that they share almost the same display. I had to swap the small card on top of the dispaly ( where Video and Function cable is attached, reverse the LED cables from left to right and swap the metal frame. It worked perfectly.
Hi Michael, can we have any pictures of what you've done ?
I think 80% of the internet won't fully understand what you are talking about (including me) and reproduce it ;)
I had this same problem and managed to fix it by frankenstein adding inverter from iMac 27 and routing 12v LCD Power on signal to enable backlight for screen.
Hello all… I’d like to add some information for those who are still struggling with this. Just a bit more of a clue, as I managed to briefly get my 24” Cinema Display to work today. Also, a cautionary tale… as I immediately fried it right after.
I’ve tried pretty much everything on this and several other threads to no avail. Today, I thought I’d give it one more go before pitching the Cinema Display into the bin. I took it all apart, put it back together while checking for loose connections. I left the glass off and the LCD connected, but not screwed down, in the hopes that I could check some connections while it was powered on. I do NOT recommend doing this. It was simply a last-ditch attempt on my part.
In the image below, you will see the heavy black cable that connects to the Logic board. I’m not entirely certain what this is, but when I unplugged it, and then plugged it back in, the monitor started working! Full brightness, brightness control returned, etc. I went about trying to repeat this, to narrow down the issue, and found that once I unplugged the power, the old problem returned (very dark, flickering if brightness is turned up, blacks out, etc). I wasn’t about to dismantle the monitor every time I wanted to use it and re-seat this plug, so I kept trying different combinations of plugging, unplugging, etc. I was able to get it to work with this method over and over… and then disaster struck. The LCD slipped out of my hand, and shorted the power supply BZZZT! So, on one hand I’m relieved that this effort is over, and on the other, happy to have finally gotten close to a solution, also… RIP 24” Cinema Display :)
I hope this information helps someone else get their display fixed, but be careful if you’re working with live juice. It’s NOT a good idea :)
Does someone know where the 3.3 v pad is on the Thunderbolt Display Board ?
Which pads i have to bridge ?
I have a black screen on my thunderbolt Display after Firmware update.
Is it maybe possible to reset delete the Firmware to downgrade where the
the PWM signal works ???
Thank to Michael very good work
Hey guys,
I have even a stranger issue. I noticed the low light on my monitor so I decide to take of the front glass and realize the problem was gone... it's bright as new.... only issue is when i put back on the front glass it gets dimmed again....
magnet issues? can someone answer this....
That is very strange, did you ever figure this out?
Hey, I solve this problem. My solution was remove the glass and take off the black tape of the ambiental light sensor and put the glass again.
Backlight LED strips need to be replaced, ether the LEDs are bad or the connector of the strips is bad because of the heat over the years…
I did replace the LED strips in the panel, which was a freakin 4 hour surgery, but the problem is still there (dim or no backlight, flickering)... before that I tried to swap the power supply, didn’t help either. So last thing that could be the problem at least in my case, are the logic board and/or cables and connectors I guess... this is horrible... :(
Got a free 27 LED Cinema Display with dark back light (BL) 99% of the time plugging in Display Port. Finally isolated a deterministic sequence that worked for a day. Wife has the same monitor and also not coming on 80% of time when plugging in Display Port. Here is the working sequence.
This sequence got the monitor up and working for a couple of hours but since then seem to have more difficulty and backlight just flickers now on the lowest sitting and shutoff at any higher settings. I guess there are thermal related weak solder points likely in the LED strip in the panel.
Need
  1. Total darkness + a flash light to help see
  2. External keyboard for the Mac/Macbook*
Preparation
Plug in Cinema Display Power
Plug in Cinema USB to Mac
Plug in Cinema Macbook Magsafe connection (probably don’t need this but might as well get MB ready to close the clamshell later while Cinema Display remains on)
Plugin Cinema mini Display Port (mDP) to Mac
Use external keyboard (pair it in advance if wireless) F1 key. Click it many times to set external monitor brightness to lowest setting (even though you think its not on)
Sequence (A)
Unplug mDP
Unpower Cinema Display (I use a power strip to repeat this sequence easier)
Wait few seconds
Power on Cinema Display
Plugin mDP, you will probably now see back light strobe dimly in total darkness
Click F2 1x (brighter), strobing probably go a little faster, wait 10s and see if it comes on permanently. if not, click F2 1x brighter and repeat until backlight stays on stable.
If backlight goes completely dark, need to restart at top of this Sequence (A)
Different/same problem as the LED strip old solder variable resistance?
This is probably the common LED strip solder resistance problem. The backlight circuit compares the different LED channels for voltage. If difference too large, circuit shuts off. Had this in my 27” iMac (2009 so same LCD panel as the 27 LED Cinema Display) It would not go very bright before self shutting off backlight. I pulled apart the LCD panel and reflowed the LED connections and now works perfect. Tearing apart the panel to get to LED strip require handy skills and cautious approach. Very easy to damage and hard to keep dust+threads out of panel+diffuser layers during reassembly. Below is the full link on that.
https://drive.google.com/file/d/13GqPCJh...
Update (08/01/2020)
Fixed 2 of these LCDs (2009 iMac 27”, Cinema LED Display 27”) Only need to apply nice leaded solder to the LED strip connectors. On my Cinema LED Display, one of the connectors just fell off the strip during disassembly. Was barely hanging on. Wasn’t just the 6 pin connection. Also the 2 connector anchor solder points. Must be really bad soldering during manufacturing.
Each connector has 6 lines so each line drives 6 LEDs (36 LED/strip). The connector solder joints is the highest thermal stressed solder joint in the circuit.
On the iMac, I also touched up every LED. I’m guessing this wasn’t necessary and the iMac color temperature is also a lot warmer. I’m guessing the heat from soldering iron affected the LEDs.
Can’t find the post now but saw an Australian tech say he fixed a bunch of these by just re-soldering the 2 connectors on the strip.
BTW, as these start fail, lots of weird symptoms. I’ve seen all of the following and varies with different logic boards.
  • Faint flickers at lowest brightness setting
  • Sometimes don’t come on if mac’s brightness is set too high during connection
  • No brightness control (after swapping a failed panel with one with early failure symptoms (still lights up but not all the time unless mac brightness is set to low at connection time)
  • Max brightness is really dim (after swapping a failed panel with one with early failure symptoms (still lights up but not all the time unless mac brightness is set to low at connection time)
Update (2/1/2023)
Fixed 10 of these by now. Always weakened lead free solder on the LED bar connector. A key trick is not remove the LED bar (thermal strip underneath will tear to pieces) and curved plastic reflector (fragile) Just touch up solder while LED bar is in the display's sheet metal tub. This trick is noted in the above pdf file link
Hi there,
On my side I've changed the logic board and no result. The power supply shows 23.9V when light is on and 24.9V when off. Do you think it can be the power supply ?
Or this issue, backlight out, can be caused by the all-in-one cable ? Possible ?
I'm in the same situation. Not sure whether to get the cable or the power supply!
There is a step-by-step troubleshooting guide in the Apple Technician Guide, see page 17.
I had this very same issue happen to me.
I have a 2014 5k iMac and 2 x 27" TB displays.
Here is what fixed it for me. Unplug the power cable from the back of the display, wait a few seconds, then plug it back in.
It has been working fine now for about 4 days so far.
Hope this helps someone else.
Bad news. Soon after this post the display no longer lights up. It works. The camera works. Just no display. :-(
@yabdab I'm experiencing the same issue, what it was?
Took it to Apple Store to get fixed, but they were unable to figure out the issue. Now it is a pretty paper weight :(
“johnny “ & “LikeARabbit” you’re absolute F*ckin’ legends! Thanks to you I saved at least 250€. Fixed my issue by inverting the LED cable and blowing hot air on the components around the connector.
Thanks for the great instructions and ideas. I was able to resurrect my 24” LED Cinema Display which was showing a no-backlight picture by opening up the display and reseating the LED driver cable connection to the logic board. This has been sitting in a recycle / donate corner for a year, and thankfully I discovered this thread and bothered because it’s big and bright and beautiful again!
Thank you for all the suggestions throughout this and other threads. I’m still having an issue with my 24” LED Cinema Display. I can get it to work with the brightness all the way down, but once I try to raise the brightness, it begins to blink and eventually goes black. I have a short video of this behavior here: https://youtu.be/4UoOGBID95I
I tried taking the display apart and reseating all the connections. Does anyone else have any other things I should try?
I have similar behaviour of my 27` Apple Led Cinema display, and there is a whole ritual to turn it on:
1. Decrease brightness on both displays macbook and external one.
2. The brightness of external display should be 70-75%.
3. Turn off power supply.
4. Turn on power supply and after connection blink start increasing brightness on external display (Ctrl + F2)
In most cases this approach works but the I've noticed that brightness level much more lower comparing before update to Catalina.
Hope it will help You temporary until some patch etc. will be released.
Thank you @sincler2013 Are you thinking this is something that can be fixed in software patch, and not a hardware issue?
@rheaney Hello, sorry for delay, I've installed the latest updated of Catalina (10.15.5) and unfortunately now the monitor screen is always black... (only sound). On previous version os the soft (os mojave) I didn't have the problem with the black screen (I had only one problem: when mac was connected with power supply and the brightness was full (there are was a sound in a bottom left corner of the monitor)
Do You have flickering after connection to Your macbook? If yes,
1. connect You display to mac with usb cable too
2. then decrease a brightness on the cinema display,
3. then turn off power supply of the monitor (not from mac, from the net).
4. connect power supply to the power net and during flickering start increasing brightness of the monitor (Ctrl + F2).
I had idea film this process but as always...smth happened and no I have this monitor as a sound bar.
I have two ideas how to check if it's soft or not:
1. Converter from thuderbolt to hdmi and another laptop
2. Mac with earlier version of MacOS
@rheaney Waiting for Big Sure release from beta and will try upgrade, if won't work will downgrade to Mojave. If nothing will help. Will go to service(
@sincler2013 and @rheaney . I have this issue with the faint backlight brightness and image flickering too. The attached thunderbolt cable was a little frayed so I replaced it, which didn't help. I followed the brightness plan listed above and it works great, but I do have some Spotlighting from the bottom of the LCD. Thanks for the help!
Can anyone tell me where R1135 is located on the Cinema 24” logic board? Someone suggested in another thread that removing it is a “dirty hack” but brings back the monitor to life.
Benjamin Nielsen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 47,820
