craig, sine it was submerged, I recommend that you do not try to turn it on or charge it, until it is cleaned. If you do not clean it, you can expect it to suffer from corrosion damage later on. Use this guide to disassemble your phone, then use 90%+ isopropyl alcohol to clean every bit of it. Use a small soft brush to clean the board, the connectors and all cable ends. Then, once it is properly cleaned, replace the battery and reassemble you phone, then re-evaluate. Hope this helps, good luck.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
