Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
crwdns2934591:0405crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Does changing Logic Board also change WiFi MAC address?
I was under the impression that the WiFi MAC address is stored in firmware on the computer. Recently I brought in the computer for logic board replacement and after one attempt to avoid the repair, Apple finally 'replaced' it, but my WiFi worked right away, with the same MAC address (wouldn't have worked otherwise). So, can the logic board be replaced while still maintaining the MAC address for the WiFi?
crwdns2942205:01crwdne2942205:0
@dan i have run into a similar issue with my mid 2017 iMac. When I replaced the logic board in it i used the preexisting AirPort card, and wifi is working but Ethernet port does not seem to connect. I have done nvram reset, SMC reset, switched ethernet cables, deleted and added the Ethernet network, reinstalled macos. Currently, i am using macos Catalina on a 2017 iMac 20.5" (EMC 3069). Is there a way to resolve the issue and make the Ethernet cable to connect?
Well sorta, the MAC address is part of the AirPort card so the tech just swapped out the main logic bd but put back your AirPort card.
Now if you had asked if the Ethernet port Mac address stayed the same the answer is no! As the Ethernet chip set is part of the main logic bd so it changes when it is swapped.
Thanks, Dan. Unfortunately the model was left off the question (MacBook Pro 15" Late 2011). I didn't think this model came with a separate AirPort card?
All of the non-Retnia MBP use a sub module for the WiFi (AirPort Card) Here's a link to the iFixIt guide in replacing it on your model MBP '15
MAC address based on your network card so when you change your motherboard your mac address will change. Even there is software to change the MAC address. How to Change MAC Address in MacBook
crwdns2942205:01crwdne2942205:0:
Almost ;-} Yes you can change your Ethernet and/or your WiFi MAC addresses using the link you posted.
But you missed the point the MAC address is part of the interface so the Ethernet interface has a different MAC address than the WiFi adapter. Here the logic board was swapped out but the AirPort card (WiFi/Bluetooth) was reused.
This also holds true for your Bluetooth and Thunderbolt interfaces as well. As an example my system has four addresses (Ethernet, Thunderbolt, WiFi, & Bluetooth, each is unique to each interface.
armtek crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,649
