Not sure what you mean by a rattle. Do you mean a "klacking" sound? That would be the motor coupling. Easy enough to change-out. Pull the body cover by removing the two screws that hold the control panel to the body, roll the control panel up, and remove the two clips on either side of the body to the rear panel using a flat head screw driver. Tilt the body back toward you, and remove. Take the clips off the pump motor, and then the clips on the motor. The coupling is a three-prong piece of plastic with a rubber cushion between it and the other coupling on the transmission. Break the old coupling, and replace with a new set, that has a metal keen-sert where it must be hammer-tapped onto the shaft of the transmission and the motor shaft. Be careful to use a 7/16" socket to tap the couplings on, or you will break them around the base on the transmission and motor posts. Realign the couplings through the rubber buffer, and re-clip the motor and the drain pump. Reassemble the body by holding the body by the top lid, tilt 30 degrees toward you at the lid, and slide the bottom of the body under the bar near the floor. Be careful to push the fill spout under the top of the body before replacing the clips, and the screws to the control panel.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
crwdns2944067:013crwdne2944067:0
Good morning. The washer works fine till it reaches the spin cycle. On the rinse cycle, it fills the tub and drains fine. You can hear the motor running. NO spinning with the agitator.
crwdns2934271:0crwdnd2934271:0 Tom Pierce crwdne2934271:0
Sorry for my delay. Didn't see this post due to a technical glitch. Either your clutch is not engaging, or your spin basket is not engaging. Check first the clutch, then the spin basket.
crwdns2934271:0crwdnd2934271:0 David Dunne crwdne2934271:0
I have had the same problem as Lisa. Tom, your issues are exactly what my scenario is, which I rectified every single time by opening the lid, watch it trying to spin, push the start knob in and pull it back out to watch it re-engage the tub. Thus proving that it isn't the door switch, but actually some other issue. But a long term fix would be better since having to keep an eye on it all the time is just a little annoying for the price paid for the machine.
I am not very inclined to start checking out clutches or spin baskets, but if there is a fix for this, it would be great
crwdns2934271:0crwdnd2934271:0 Robert Brunet crwdne2934271:0
It needs to be recalibrated...
crwdns2934271:0crwdnd2934271:0 anonymous 8759 crwdne2934271:0
Kenmore/Whirlpool 70 Series washer are not capable of having a calibration. They are manual control systems. The lid switch is all that can be replaced. Now, a Kenmore 300 or 500 would need a calibration done through the main controller, but a 70 Series is a manual dial timer system. No calibrations are performed.
crwdns2934275:08crwdne2934275:0
