crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Roomba will not power on.
Roomba fails to come on.
Roomba did not properly dock after cleaning cycle.
After cleaning cycle Roomba returns to charging base and fails to dock properly. Manually place device on docking station and ensure indicator lights are illuminated. Look for troubleshooting indicator to indicate any component problems.
Tip: Ensure that no debris is blocking Roombas access to docking station.
Reset Device.
Press and hold the clean button for 10 seconds until all lights illuminate. A tone will signify a successful reset.
Note: This will clear scheduled cleanings, reset the clock and resolve some software issues.
Contacts on Roomba are bad.
Roomba will not charge even if manually placed on the docking station. Ensure all contacts are clean and that the docking station is plugged into to a proper outlet. iRobot recommends replacing these contacts every 6-12 months depending on usage.
Battery needs to be replaced.
Troubleshooting indicator will come on and a voice message will identify the problem. The battery is easy to access on the underside of the Roomba. This guide will walk you through the steps.
Roomba favors one side.
Roomba fails to navigate open areas properly pulls to one side or makes circles.
Drive wheels are dirty.
Visually inspect drive wheels for debris in treads or trapped around wheel housing. Clean any debris from treads or housing with a brush.
Drive wheels are damaged.
Visually inspect drive wheels for damage or malfunction. If any damage is found remove and replace drive wheels. Replace the individual drive wheels by following this guide.
Roomba not cleaning around objects or walls.
Dirt and dust bunny build up noticeable around objects or walls. Side-brush is either damaged or side-brush motor is out. Inspect side-brush to determine which problem is the root cause.
Side-brush damaged.
Side-brush has broken one or more of its arms. Follow this guide to replace the side brush.
Side-brush motor has failed.
Side-brush still has all of its arms, but the motor will not turn. Follow this guide to replace the entire side-brush motor assembly.
Roomba not thoroughly cleaning floors.
Clumps of dirt left behind after cycle. Extractor rollers are dirty or damaged. Dustbin is full or dustbin motor has failed.
Dustbin is Full
Roomba has an indicator light that illuminates when dustbin needs to be emptied. Follow the instructions in your Roombas manual to empty the dustbin.
Extractors are dirty or damaged
Extractor rollers can become tangled with debris during normal cleaning cycle. Remove rollers from assembly and inspect for damage or debris. Follow this guide to replace damaged extractors. Entire extractor assembly may fail, if the entire assembly is bad follow this guide to replace it.
Dustbin motor has failed
Device will not clean and you will not hear the motor running and no air will be moving out of the Roomba. Remove dustbin and inspect motor for damage. If motor is damaged a replacement dustbin can be ordered.
Justin Tolin
crwdns2935283:005/29/19crwdne2935283:0
736 crwdns2915208:0crwdne2915208:0
South Arkansas Community College, Team S1-G1, Mitchell Summer 2019 crwdns2935289:0South Arkansas Community College, Team S1-G1, Mitchell Summer 2019crwdne2935289:0
SACC-MITCHELL-SU19S1G1
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,689
