crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
iFit Act won’t turn on
When the button is pressed, nothing happens.
Dead Battery
If the iFit Act does not turn on when the button is pressed, you may need to replace the battery with a new one.
Battery Setup
If the iFit Act does not turn on, you may need to perform a hard reset (refer to iFit Act Battery Replacement for instructions).
App and website won’t sync properly
Information on the app doesn’t show up on the website. Information on the website doesn’t show up on the app.
Phone Not Syncing
Check to make sure the phone’s Bluetooth is marked “visible.” Then, with the app open, try re-syncing the device. To re-sync, press the tracker pod’s button once and release when it turns red. Press the button again, then keep holding the button until it blinks (red) rapidly. The blue bar on the phone should load (from left to right across the top of the screen). The iFit recommended syncing frequency for the tracker is at least once a week; otherwise the data recorded on the tracker pod will be deleted.
Website Not Syncing
Refresh the webpage; wait five minutes for the page to update. If the app and website don’t sync when you login to the website, logout before attempting to login again. Sync the app to the phone before attempting to sync to the website. If the app and website don’t sync automatically, you may need to wait a few hours.
Sleeper mode not syncing
The iFit Act isn’t recording my sleep, or that information isn’t showing up on my app.
iFit Act won’t sync with app
If the iFit Act will not sync your sleep data, try adding the information manually from the app (not the website). Information added manually to the app syncs to the website; information added manually to the website does not consistently sync to the app.
Pedometer not working or slow to update
After trying to log a workout on the tracker, my steps don’t show on the app.
Pedometer data doesn’t show on the website
If the pedometer data does not appear on the website, try waiting a couple of minutes and then refreshing the website.
Pedometer data doesn’t show on the app
If the pedometer data does not appear on the app, try waiting a couple of minutes before re-syncing the device to the app. (See "synching" tips.)
If that doesn’t work, go to “Settings” on the app, then click “Advanced.” Under advanced, set where you are wearing the device (left or right hand). Also, make sure your device is calibrated (go to “Settings,” then “Calibrate”). Now try syncing the device to the app again.
If all else fails, try a hard reset.
Can’t enter food calories
I’m having trouble entering my food calories on the website and/or app.
Can’t enter food calories on website
If you can’t enter food calories on the website, try adding the information from the app. Information added to the app does sync to the website; information added to the website does not consistently sync to the app.
Negative calories
If you’re seeing negative calories, it may be because you have exercised but not entered any food calories yet. If you enter food calories but you still see negative calories, then you’re seeing how many calories you’ve burned, taking into account how many calories you ate.
Wristband fits improperly/causes skin irritation
The iFit Act wristband is uncomfortable and/or doesn’t fit in a way that allows the tracker pod to record data.
If the wristband does not fit comfortably or in a way that allows the tracker pod to record data, try the other size included in the iFit Act package. (The iFit Act is sold in packages that include a Small/Medium and Large/XLarge-sized wristband.) If this size also does not fit comfortably, iFit Act users have found the clip-on accessory sold with iFit’s other 3-in-1 tracker, the iFit Active, more wearable. The clip offers you the option of wearing the iFit Act on your waistband or pocket. If neither wristband fits, iFit recommends contacting their Customer Care team at support@iFit.com.
Wristband causes skin irritation
The iFit Act wristband causes a rash and irrates my skin.
Many users have reported rashes caused by the iFit Act’s wristband. If you are experiencing skin irritation from your iFit Act, make sure the wristband is completely dry before you put it on. iFit recommends regular cleaning of the wristband with warm water and a few drops of liquid soap.
If the wristband is still causing skin irritation, you can carry it in the pocket of your shirt or pants. As long as the tracker pod is on your person, the iFit Act should record data.
Chakrik Veeramoothoo
crwdns2935283:009/29/15crwdne2935283:0
4 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of Maine, Team 1-1, Diaz Fall 2015 crwdns2935289:0University of Maine, Team 1-1, Diaz Fall 2015crwdne2935289:0
UMAINE-DIAZ-F15S1G1
crwdns2944067:011crwdne2944067:0
I can't plug in my ifit it just won't plug in!
Holli speechly - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Walking track on my NordicTrack C700 does not start moving when turned on - I have to manually push on it to get it started before it “catches” and noise coming from under machine while operating. Do I need to lubricate anything underneath? Thank you
Carole Anne Parnell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hola
Tengo una caminadora Proform 205, no funciona el botón start, por lo cual no puedo iniciar los programas de ejercicios.
Existe otra manera de arrancar directo de la app, sin tener que presionar el botón start de la caminadora
José Fernández - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I use an iPhone 8 and 11 pro max and the app refuses to open on both phones when downloaded
Samantha J - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My bike is connected to the app but my stats will not show up on screen during the workout. Rpm’s, calories, etc all say 0, and the workout does not save.
Hannah Howard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 31,583
