crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Console Won't Turn On
When the power button is pressed, it does not light up green, and nothing appears on the connected display.
Console not plugged in correctly
If the console does not turn on, this can be an indication of a problem with the supply of power to the device, most often caused by a simple mistake of some sort.
One should check that the power supply cord is:
  • The power supply cord that came with the device
  • Plugged into a functional wall outlet (and not plugged into an extension cord or surge protector)
  • Fully plugged into the console
(Also, make sure that you didn't forget to pay your electrical bill)
Power supply reset by power surge
Due to the nature of the power supply's (cord) built-in surge protector, if it experiences a power surge, it will temporarily stop delivering power to the console.
To fix this:
  • Step 1: Unplug the power cord from the console and the wall
  • Step 2: Wait 10 seconds
  • Step 3: Plug the cord back into the console and attempt turning the console on
Power supply cord issues
The power supply cord could be faulty. One can obtain a replacement power supply cord from Microsoft.
Internal power supply issues
The power supply within the device could also be malfunctioning. Here is a guide for the replacement of the internal power supply.
Motherboard problem
If all above steps and actions have been followed in order, and the console still will not turn on then the console could have. Here is a guide to replacing the motherboard.
The Console Does Not Offer 4K Visuals
4K visuals are not applicable.
TV is setup incorrectly
You might not have the HDMI cable attached to the right port on your television. This may be limited to only one 4K port, so connecting the Xbox to the wrong one will force the console into HD mode.
If you cannot identify which port is for 4K, read your TV’s manual. Plugging in the HDMI cable into the soundbar before your TV might not let the 4K pass through. You must plug it in directly to troubleshoot.
Game does not support 4K
The game you have installed or put into the console may not support 4K visuals. Especially games that were updated for the new system may still have their original formatting. Some developers may have even decreased the visual performance of their games in exchange for better framerate.
A “4K” logo should be apparent on the cover of the game if it is designed for 4K resolution. Otherwise, the game will render at its maximum resolution for the 4K television.
Game software is not up to date
Developers for some games are still releasing small patches of updates to enhance their graphics at their own pace. It is possible you have not yet received that update for your particular game:
  • Step 1: Connect your console to Xbox Live
  • Step 2: Go to My Games and Apps
  • Step 3: See if there are pending updates
Note: Some updates take up to 100GB of data storage or more, so be aware that this may take some time.
The Console Will Not Connect To Wi-fi
The device will not pick up the Wi-fi signal.
Router not working
It is possible that the wifi network you are using is not working. Check other devices to see if they are also having connectivity issues. If issues exist, contact your provider for troubleshooting the issue.
Console will not connect
If the issue only exists on the console, try to reconnect to the network:
  • Step 1: Open the settings app
  • Step 2: Select network
  • Step 3: Select network settings
  • Step 4: Choose the setup network option to connect to the wireless network again
The Game Installation Progress Bar Remains at 0% Indefinitely
The user waits from minutes to hours for games to install, but there is no sign of progression.
Hard drive is full
The hard drive can run out of memory while attempting to download new games. To fix this, you can either delete old games or buy an external hard drive.
Won’t install from disk
If you are trying to install the game from a disk, remove the disk from the console. After selecting the menu button on the controller, open up the manage section. Then, delete the files that have already been installed. Now, reset your console and start the installation process again.
Slow internet connection
If the game will not install, internet connectivity issues may be to blame. Check the above section, “The console will not connect to wifi” to see how to fix this issue.
The Console Turns Off Unexpectedly
In the middle of use, the entire console will shut itself off.
Console is too hot
If the device feels hot to the touch or is getting improper ventilation, follow these steps:
  • Step 1: Turn off the console
  • Step 2: Wait at least an hour
  • Step 3: Ensure that the console is in a well-ventilated spot
  • Step 4: Turn the console back on
Power supply problems
If the power supply is causing issues, try resetting it by following these steps:
  • Step 2: Wait ten seconds
  • Step 4: Press the Xbox button on the front of the console
Also, ensure that the wall outlet is working.
Game installation issues
If the console continues to shut down when playing a specific game, try uninstalling the game:
  • Step 1: From the dashboard, select “My Games & Apps”
  • Step 2: Highlight the game to uninstall and press the menu button
  • Step 3: Select “Manage Game” from the menu
  • Step 4: On the next screen, select uninstall
To reinstall, go back to the “My Games & Apps” screen. Then, select the game from the “Ready to Install” section.
Ashley Masuda
crwdns2935283:001/24/18crwdne2935283:0
2.994 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G6, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S2-G6, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S2G6
crwdns2935297:082crwdne2935297:0
crwdns2944067:013crwdne2944067:0
My Xbox one Scorpio Edition is not letting me download any games and no my storage is not full and also it stop the installation quite quickly and sometimes it starts on the error menu showing a code?
Ricardo Jimenez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@rmjd69 did you resolve this? If so, how? Thanks
Gabe Williamson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I plug my console in today and turned it on. Make some odd buzzing sounds near the power cable. Turned on then $@$* off right away. Unplugged everything and plugged back in same issue. Help please
J Lord - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same issue as J Lord, it’s making a buzzing sound near the power cable and it turns on but then shuts off
Gabe Correia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 15,201
