crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If you are unable to connect your other devices to your W-King X10 via Bluetooth. Follow this guide to troubleshoot various possible solutions.
Device is too far away
Ensure that your device is within the operating range of the W-King X10. Typically, this is around 10m or 33 ft, but this can vary depending on environmental factors. Bring your device close to the X10 and check your Bluetooth connection menu for "W-King X10".
Another Device Is Already Connected
Only one device can connect to the W-King X10 at a time. The X10 will default to the first device that attempts to connect with it. Check any other nearby devices that have connected to the X10 in the past and make sure to disconnect any from the X10 before attempting to connect the device you want.
W-King X10 is Not in Pairing Mode
When you turn on your W-King X10, it should automatically enter pairing mode, indicated by a blue flashing LED indicator at the top of the X10. If you do not see the blue flashing light, reset the Bluetooth by the following steps:
  • Take a straightened paperclip or toothpick or another narrow object
  • Find the reset pinhole, located on the connection panel and labeled “RST”
  • Short-press the reset button to reset the Bluetooth
  • The LED indicator should begin flashing blue
Bluetooth Module Failure
Reset the speaker using the steps above to clear minor program errors. If your X10 still does not enter pairing mode, the Bluetooth module may have failed. Since the Bluetooth module is soldered to the motherboard, replacing it requires a board-level repair. If you prefer not to attempt this, follow this guide to replace the motherboard and resolve the issue.
Justine
crwdns2935283:009/07/24crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-2, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-2, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G2
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 3,253
