crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Microphone does not work
You're using your headset to communicate with a friend while playing a game, but they cannot hear you.
Microphone placement
The microphone attached to your headset must be rotated in front of your mouth approximately 2-3 inches for best capturing of your voice.
Loose connections
Double check all of the wires are connected properly. More specifically the USB cable, and the cable leading to the inline amplifier.
Inline amplifier isn't set properly
If the microphone doesn't work, it could be a connection with the inline amplifier. The microphone switch on the inline amplifier needs to be in the on position the switch should line up with mic icon. If a red LED light appears that means the mic is muted and if purple then its in phone call mode. To check to make sure your mic is working you can turn up the mic monitor dial so you can hear yourself talk.
If these troubleshoots don't work, you may need to replace the microphone with our microphone replacement guide.
Audio only in one ear
Sound is only playing out of one side of the headphones.
Loose connections
Double check all of the wires are connected properly. These include the white and red RCA cables, the USB cable, and the cable leading to the inline amplifier.
If the audio only plays out of only one side, it could be an issue with the inline amplifier.If a purple light appears on your inline amplifier then its in phone call mode and will alter your audio. More often than not, the settings on the amplifier need to be adjusted.
You could have a faulty or damaged speaker if troubleshooting doesn't work. Our Speaker Replacement guide can help you fix it.
Headset overheating when connected to computer
I connected my headset to my computer and it got very hot, as well as the inline amplifier.
Too many devices plugged in the USB ports
If your computer is being overworked, by the amount of devices plugged into its USB ports, then it may cause your headset to overheat. Try unplugging all devices plugged into the USB ports on your computer and only plugging in the PX22 headset.
The computer may not be accepting the headset properly
If there is a suspected malfunction in the connection between the headset and the computer, you should try plugging your headset into another computer to test if it functions properly there and does not overheat.
If this doesn't solve the problem then you may have a broken USB. Check for damage along the cable and around the USB. You can look for a computer-specific USB repair guide here on iFixit to help you repair or replace a faulty USB port.
Multiple headsets on one console
After one headset is set up and functional, how can you hook up another device and have them both functional, so you can simultaneously listen and communicate with all headsets.
Cannot hook up second headset
Multiple headsets can be used on one console, but only as headphones. The chat option is only applicable for one headset at a time. The PX22 is installed to your TV using RCA cables, one white and one red. Both wires have ends with both male and female plugs. You can plug one set of wires into the other set, keeping them color coordinated. Both headsets will then receive game audio.
Connecting to Skype and other computer chat programs
How to set up the PX22 headset to use on Skype or other computer programs.
Can’t hear audio and/or microphone does not send voice through the computer.
The 3.5 mm plug from the headset should be plugged into the in-line amplifier’s jack. The amplifier’s plug should then be connected to the headphone jack of the computer. The USB from the amplifier should be connected to a USB port in the computer. Continue to either Windows 7 or Mac if applicable.
Windows 7
After following the steps to connect the device to the computer, go to the Start menu and select the Control Panel. In the Control Panel select Sounds and make sure that you’re in the playback tab. Make the headset the default playback by right-clicking Turtle Beach PX22 headset and selecting Set as Default Device. Next go to the Recording tab, right-click on Turtle Beach PX22 microphone and choose Set as Default Device.
Mac
After connecting the device to the computer in the above steps, go to the Apple menu. In the Apple menu go to System Preferences and then Sounds. In Output select Turtle Beach PX22 as the default speakers. In the Input tab select Turtle Beach PX22 again as the default microphone.
If these don't fix the problem, refer to our other troubleshooting guides. You may need to refer to the Ear Cushion, Speaker or Microphone replacement guides if the problem persists.
James de Iturrondo
crwdns2935283:003/18/15crwdne2935283:0
709 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-1, Duarte Spring 2015 crwdns2935289:0UMass Dartmouth, Team 3-1, Duarte Spring 2015crwdne2935289:0
UMASSD-DUARTE-S15S3G1
crwdns2935297:048crwdne2935297:0
crwdns2944067:06crwdne2944067:0
i can hear people but for some reason they cant hear me if you know how to fix this on the PX22 Please msg me if you have kik = TheRealAusNick
Nick Symes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have an issue not listed here. My master volume is being controlled by the chat volume knob instead of the volume knob. Ideas?
Josh Barnes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yeah, I'm having that problem too!
Jason French - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same problem. Any solution already?
patriciasengl - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 13,248
