crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Voice Command Does Not Register
The device no longer responds to voice commands.
Software Malfunction
Sometimes a software update will cause voice commands to malfunction. To fix software malfunctions of voice commands, reset the device by holding down the power button for at least 15 seconds. After holding down the power button, a drumming noise should indicate a reset.
Damaged Microphone
Consult the user manual about voice command requirements. The device may require special phrases in order to begin a command. Special phrases include, but are not limited to "all commands" and "clear route". If these commands still do not register, open the device. Check the opened device and connect the microphone cable to the motherboard.
Keys Do Not Register Or Register Only Hard Presses
The device no longer responds to soft taps on the screen.
Dust Inside The Screen
Dust and debris may enter the device and prevent the device from registering commands. To remove dust and debris, open the display. After opening the device, separate the display from the digitizer and use a microfiber cloth to clean the underside of the display and front of the digitizer.
Failed Digitizer
Consult the user manual and calibrate the touchscreen. Tap various parts of the screen. The digitizer needs replacement if the device registers keys on the entire screen, registers incorrect commands, or does not register at all.
Cracked Screen
A cracked screen does not necessarily indicate a damaged digitizer. A cracked screen will indent and apply pressure to the digitizer. The digitizer registers soft, normal taps and will require hard taps to overcome pressure from the screen. Replace the screen to fix this problem.
Display Does Not Work Or Shows Visible Line
The display fails to boot or has damage.
Failed Digitizer
A faint visible line on the display indicates that the digitizer experienced electrostatic discharge. Electrostatic discharge can damage and cause electronic components to fail. Replace the failed digitizer to fix this problem.
Cracked Screen
Dropping or smashing the device can damage the display, causing it to not work. Replace the display to fix this problem.
Damaged Digitizer
The device has a capacitive touch screen, and therefore functions through light taps. Tapping the screen too hard could damage the display. Replace the display to fix this problem.
Device Becomes Incredibly Hot
The device becomes warm to the touch after a few minutes use.
Damaged Battery
If the back of the device becomes incredibly hot after an hour's use, the battery converts more energy to heat than it supplies to the system. The entire system will experience strain from this heat. Replace the battery to fix this problem.
Distorted Audio
The device lacks clear sound.
Enabled Software Mute
Consult the manual if the device has a software mute option. If not muted, check the volume settings and set the device at an audible volume.
Failing Or Damaged Magnets
The speaker produces a hissing noise when the magnets inside the speaker become damaged. The magnets cannot leave the speaker, so the entire speaker needs replacement.
Device Does Not Power On
The device fails to boot when prompted.
Software Error
A soft reset may cause the device to boot again. Follow TomTom's official reset instructions.
Damaged Charging Cables
Inspect the charging cables for bent outlet prongs, tears in the wire, and broken ends. Damaged power cables will need replacement, but bent prongs will return to normal by forcing them back in place. Leave the device charging for four hours. If the device does not charge properly, consider purchasing a micro USB to USB cable and a USB to wall adapter. Use the new cables to charge the device.
Loose Internal Cables
Cables connected to the motherboard may have become loose. The loose cables cause the device to function improperly. To fix this problem, open the device and reattach loose cables.
Old Battery
After a full charge, the battery holds enough energy for one to six hours of use. If the device requires charging after less than twenty minute's use, then the device needs a new battery.
Ports Do Not Work
Cables or SD cards do not interact with the device.
Software Error
A soft reset may cause the ports to work again. Follow TomTom's official reset instructions.
Dust And Debris In The Ports
Check the ports for dust and debris. Removing the dust and debris sometimes requires using an air canister. If the air canister does not work, the ports need replacement. Replacing the ports requires replacing the motherboard.
Nicholas Maharaj
crwdns2935283:009/22/16crwdne2935283:0
UC Davis, Team 2-5, Oliver Fall 2016 crwdns2935289:0UC Davis, Team 2-5, Oliver Fall 2016crwdne2935289:0
UCD-OLIVER-F16S2G5
Im trying to do a soft reset on my tomtom 500 so it recognises the SD card. I cant find the hole to do the reset. Can anyone help. I dont want to do a factory reset.
Jacqui Riley-Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 53
crwdns2959996:0crwdne2959996:0 4,764
