Calculator won't turn on
You have tried, but your calculator won't to turn on.
Bad Batteries
The batteries in your calculator may be dead. Try changing the four triple AAA.
Low Contrast
The constrast on your screen may be too low and you can't see what is there. Try pushing the on button and then pushing the [2nd] button and the up button to increase the contrast.
RAM Issue
The memory in your calculator may be corrupted. Remove one AAA battery and press and hold [CLEAR] , while you are holding the button reinsert the battery.
Bad operating system
It is possible the operation system is malfunctioning on your calculator. Remove one AAA battery and press and hold [DEL] , while you are holding the button reinsert the battery.
If nothing else works...
Your calculator's motherboard may be bad, you can try replacing it. Here are some helpful instructions.
Buttons don't respond
You are pushing the buttons but nothing is happening.
Bad Keyboard Contacts
A keyboard contact may have shorted, replace the keyboard which is part of the motherboard. You can get instructions here.
Torn Keyboard Mat
The keyboard mat in your calculator may be torn or damaged. It can be replaced with these directions.
Broken Key
If a key is cracked it may not be pushing on the keyboard mat properly. Install a new key with these instructions.
Screen has black spots or is glitching
for some reason black spots are on your screen.
Bad screen
Pressure was most likely applied to the screen and the crystals are damaged, replace the screen with these useful instructions.
Broken Case
Oh No! You dropped your calculator and the case is cracked.
Cracked Case
Your case is broken and needs to be replaced. You can find instructions here.
Programs and Variables Disappear
When you try to access a program it isn't there.
Dead Back-up Battery
The battery that runs the memory when the main batteries are out is dead. It can be replaced with these instructions.
Michael Schuster
crwdns2935283:010/01/12crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 18-37, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 18-37, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S18G37
crwdns2944067:024crwdne2944067:0
I can't open the back to change the batteries in my TI 83 plus calculator. I don't think there is batteries in it. What should I do?
pisces312k - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
thank you so much. I tried some tips in this post and my calculator finaly works. it turns out there is somethibg wrong with RAM.
mickizhuo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
THANK YOU! i inserted my batteries and it still didn't come on. I googled and came to this page and tried the RAM issue option and it turned right back on.
christianxjones - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My calculator won't work, my water bottle spilled in my back pack while my calculator was inside. And now the screen is acting glitchy what do I do?
Savannah Anaya - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 73
crwdns2959996:0crwdne2959996:0 85,410
